SIL9385 Replacement
  • mu2
    • Oct 2009
    • 217
    SIL9385 Replacement
    I have a main board with an hdmi chip that needs replaced.
    The chip is a Silicon Image SIL9385 and the package is a 100 pin tqfp.
    I have some of the low temp alloy that will desolder the pins but this chip has a ground pad underneath.
    Can someone recommend a way to remove and reinstall the new chip? I have a hot air station but no preheater for the underside of the board.
    Thanks,
    Mike
  • diif
    • Feb 2014
    • 6978
    • England
    Re: SIL9385 Replacement
    If the chip has failed you can use hot air to remove. Getting it too hot doesn't matter.
    Once the old solder is removed you can use solder past for the centre pad and hot air to replace.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      maybe use a hair dryer on the underside of the board whilst heating it from the top with your air station i know it wont get as hot as a proper hot air station but any extra heat will help with removal.
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • ebugs
        Asus laptop EC/SIO chip replacement
        by ebugs
        Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
        I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
        I found the EC chip...
        09-14-2024, 02:09 AM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • capoplays
        Help with BIOS update on Dell G15 5515 after chip replacement
        by capoplays
        Hey everyone,
        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
        When I check the BIOS using the F12 menu Flash...
        10-24-2025, 06:53 AM
