Vizio E291-A1
  • staze
    • Mar 2008
    • 41
    Vizio E291-A1
    Hi All,
    I have one of these TV's that just went dead on me. I don't have the PS values handy, but from what I recall, the PS-On and the DIM-On were both showing as 0V when the unit is on and off.
    It does the typical power on, no backlight, sound, video, and won't turn off until you pull the power.
    What's interesting is there's some definite "switching" voice coming from the main PCB. I'm not sure if that's due to the EEPROM being bad, and the CPU not firing up, or if something else is going on. That switching noise appears on both the "dead" PS-On and DIM-On lines measured with an oscilloscope.
    I'm happy to buy a new EEPROM, but my big question is, what causes the corruption/failure? A batch of bad chips, crappy design of the display, failing regulators? I'm just worried that I'm going to have to keep replacing this IC every few years. =/
    Attached is a picture of the main board. The EEPROM IC is a winbond chip. I thought I had a picture of just it, but I'm not able to make out the exact IC model. Also interesting is there's, what looks like, a silver sharpie mark on U408. Not sure if that's from someone confirming it worked, or what. If anyone has values for what various regulators should output, I can also check and confirm that. Seems like there are a lot of redundant VRs... several 3.3v regulators, several 5V regulators. Guess that's just cheaper than paying for an extra layer on the board. The build quality of these TVs is pretty darn crappy. =/
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio E291-A1
    Try freezing eeprom. May have bad capacitor if you have noise
    • staze
      • Mar 2008
      • 41
      Re: Vizio E291-A1
      swapped out the caps that seem likely, no change. swapped out VR, no change. Somewhere on that side of the board, there's a relatively low impedance path to ground (136R). So working on tracking that down. Guessing it's not the eeprom.
      • staze
        • Mar 2008
        • 41
        Re: Vizio E291-A1
        hmm... managed to get a replacement main board to test with, and shows the same symptoms.
        So either it's the power supply (not sure how, unless one of the dim/on-off rails is shorted), or I have a blown LED backlight.
        Any suggestions how to test?
        • dskall
          • Oct 2016
          • 2905
          • usa
          Re: Vizio E291-A1
          Need to post some voltages from power supply. Also unplug ir sensor and wifi if it has one. See if that changes anything
          • staze
            • Mar 2008
            • 41
            Re: Vizio E291-A1
            Okay, here we go:
            Off, from the dim pin being pin 1.
            0v
            0v
            0v
            0v
            0v
            0v
            0v
            0v
            0v
            0v
            5.2v
            5.2v
            On:
            0v (50mv)
            0v (80mv)
            12.5v
            12.5v
            0v
            0v
            0v
            25v
            25v
            4.5v
            5v
            5v
            Disconnecting backlight makes no difference. Also tried pulling the pins for the dim and on/off and that made no diff. Have not yet tried to force them on with a 1k resistor between the 5v standby and the on and dim pins.
            So either the new board I got is bad, or... it's not the main board.
            • CapLeaker
              Leaking Member
              • 8214
              Re: Vizio E291-A1
              The main board is returning PSon. That's good. However the main board is not turning the back lights on (On/Off). That is not so good. Bad main board.
              SJ sells a main board repair kit that you could try, or get a new main board.
              So if you disconnect the main board and jump STBY voltage to the PSon and the On/Off pins through a 1k resistor for each pin and plug the PSU in, the PSU should fire up and the back lights should be on.
              • staze
                • Mar 2008
                • 41
                Re: Vizio E291-A1
                So "new" board I got was also bad? Any chance it's something else? I'm happy to buy parts to replace, just want to make sure I'm not wasting more time. Also before I send note to ebay seller about replacement board.
                Thanks!
                • CapLeaker
                  Leaking Member
                  • 8214
                  Re: Vizio E291-A1
                  PSon and BLon are generated on the main board. BLon isn't there, the main board is bad.
                  • staze
                    • Mar 2008
                    • 41
                    Re: Vizio E291-A1
                    figured. thanks!
                    • staze
                      • Mar 2008
                      • 41
                      Re: Vizio E291-A1
                      so, another question before the repair kit: what causes the failure? bad parts, bad power supply? some hardware design fault on Vizio's part?
                      • CapLeaker
                        Leaking Member
                        • 8214
                        Re: Vizio E291-A1
                        could be low quality parts, some esd discarge etc... Vizio's are known for bad solders, bad voltage regulators, etc. However I don't think your PSU is bad.
                        The repair kit states that it "may" fix that problem. See what a replacement board vs the repair kit costs.
                        • staze
                          • Mar 2008
                          • 41
                          Re: Vizio E291-A1
                          Got the repair kit from SJ, and it worked perfectly!
                          Thanks All!
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Re: Vizio E291-A1
                            Can you say what components needing to be replaced were in the repair kit which could help others having the same problem.
                            • CapLeaker
                              Leaking Member
                              • 8214
                              Re: Vizio E291-A1
                              glad to hear that your TV is up and running again.
                              • staze
                                • Mar 2008
                                • 41
                                Re: Vizio E291-A1
                                So, hopefully SJ won't get mad at me, but the kit came with 4 ICs. The EEPROM (U409), and Buck converter (U704), and two mosfets (Q702 and Q706). Only thing I noticed was the thermal pad on the back of U704 wasn't soldered very well when I removed it. I made sure it soldered quite well when replacing it. Note, you'll probably want a heat gun/rework hot air station to remove that chip. You may be able to heat enough from the back of the PCB with an iron to remove it, but I've never had good luck with that.
                                Attached is the image of which ones get replaced.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Re: Vizio E291-A1
                                  Thanks for the update. Will prove useful to anyone else who may have this problem.
                                  • staze
                                    • Mar 2008
                                    • 41
                                    Re: Vizio E291-A1
                                    I'll note I bought the kit over ebay from SJ because it had free shipping. The amazon store from SJ was more, and directly from SJ had shipping. So, make sure to check. =)
                                    • edgarmg15
                                      Damaged EEPROM on TV Vizio E320-A0
                                      by edgarmg15
                                      Hi everyone
                                      I´m trying to repair a TV Vizio E320-A0 that I found in the street
                                      The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
                                      The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
                                      So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
                                      11-19-2022, 03:46 PM
                                    • RDC55
                                      Vizio a320-a0 eeprom
                                      by RDC55
                                      I was trying to repair this Vizio 32 inch and have isolated it to the EEPROM. The symptoms are it does not respond to the power button and so no backlights or any indication that the button was even pressed. Applying freeze spray to the EEPROM while the set is unplugged, and then plugging it in and all is well.
                                      Now I know I can buy pre-programmed EEPROMS for $15.00 or so, but I wanted to do this myself. So, the original EEPROM is Winbond 25Q64FSIG. I ordered this but received a 25Q64JSIG, which has slightly different timing characteristics. Well, being hopeful...
                                      04-28-2021, 09:06 AM
                                    • SidneyCanadas
                                      93C46 and 93C56 EEPROM
                                      by SidneyCanadas
                                      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                                      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                                      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                                      06-14-2023, 01:16 PM
                                    • SS454
                                      vizio e650i-a2 backlight flashes then turns off
                                      by SS454
                                      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                      panel: au optronics T650HVN05.4
                                      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                      https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                      08-20-2020, 03:57 PM
