LED current consumption in LED LCD TVs
  • Ahakim
    • Apr 2013
    • 64
    Is there a way to reduce the number of leds (3 arrays, 7 leds in each in the 32" LG TV I'm working on right now... no backlight) without loosing on lighting and picture quality...? 3 strips of 6 in each for instance? Should I in this case introduce a resistance somewhere in the circuit to assure right current value, in order to protect the new leds?
  • petehall347
    • Jan 2015
    • 4449
    Re: LED current consumption in LED LCD TVs
    light will obviously be less .. use diodes in place of missing led.s .. get the ones with same vf as led.s
      Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
      I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
      I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
      I tested the battery cells there are installed right now and they are testing good with no issues that I...
      02-04-2025, 08:08 PM
    • unimatrix93
      Which resistor should I remove/replace to decrease current to backlight leds?
      by unimatrix93
      Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
      However I need some help identifying the resistor I need to replace to achieve this.
      Thank you!
      11-29-2024, 05:05 AM
      Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
      The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
      All AP21X2SG-13 AP21X2MPG-13 devices are available...
      10-23-2024, 03:33 AM
    • DynaxSC
      Extreme High Current & Low Voltage Short Killer ??
      by DynaxSC
      Hi Folks
      I'm looking for a extreme high current short killer solution for a reasonable cost.
      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
      After taking off the socket, the shorts dissappear again.
      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
      10-15-2024, 10:13 AM
    • Pipolups
      Corsair K70 LUX RGB dying LEDs
      by Pipolups
      Hi there !
      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
      10-08-2024, 11:58 AM
