JVC JLC47BC3002 47" LCD TV Dead - No power on , no lights
  • diif
    • Feb 2014
    • 6978
    • England
    Re: JVC JLC47BC3002 47" LCD TV Dead - No power on , no lights
    A failed eeprom can show itself but not being able to be detected or read in an external reader. A blast of freeze spray or compressed air upside down can also cause an effect. Give it a blast and try and turn on the tv.
    • nsilvang
      • Mar 2017
      • 26
      • mexico
      some body have bkp bios for this tv jlc37bc3002
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
      • SuperAman
        PS5 dead no beeps, no lights
        by SuperAman
        Got a PS5 with no power. I can read some voltages on the back side of the board with PS connected. I do believe I have 12v coming in and I have found 3.3v, 5v on the board. I do have 12V on + terminal of all the electrolytic caps pictured. I believe I have a short on the vcore / apu supply? All the APU 1V small coils all 6 on both sides of the board are reading around 0.6 ohms on both terminals. I believe console may be dead due to a shorted usb port which I was able to unbend the pins. Do I have a shorted mosfet or possibly bad ceramic small cap or a dead apu? The usb ports are connected directly...
        11-29-2023, 06:34 PM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • Spent5
        ASUS GA401QM dead no lights
        by Spent5
        i have this asus laptop. This laptop was bought not working.
        Initially I found corrosion in the 2 attached photo's and after cleaning that with ipa boom it worked
        then it just stopped again.
        here is what i have discovered so far.
        i checked the first 2 mosfets by dc in jack no voltage is passing from drain to source on the first mosfet.
        see circled components on other 2 photo's the circled mosfet has a gate shorted to ground and the other photo that component is shorted to ground
        I'm really not sure where to go...
        06-10-2025, 11:38 AM
