Vestel 17ips20 said goodbye
  • Eddy1000
    • Jan 2017
    • 20
    • MyCountry
    It happened again.
    Our 40" Vestel TV has said goodbye.
    He is completely dead, no standby light.
    The ReeceyBurger123 youtube video i have seen.
    A Vestel 17IPS20 is installed. The fuse and diodes aren´t short.
    At the two 450V capacitors are only 24V.
    Secundary side also dead.
    Can someone help me?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Vestel 17ips20 said goodbye
    Sounds like you got a dud unit buddy or one for a different mainboard. You cannot use a IPS20 for 17MB95 on a 17MB82 for example if thats alright you have a bad board from the seller.
    • Eddy1000
      • Jan 2017
      • 20
      • MyCountry
      What do you mean?
      These are the original Parts from the TV.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        is this the tv your working on ?
        https://www.badcaps.net/forum/showthread.php?t=59974
        • Eddy1000
          • Jan 2017
          • 20
          • MyCountry
          No, the 32" (link) is (was) the bedroom-TV.
          This is the 40" livingroom.
          Both a little bit older than two years... nice quality
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Test Q216, C525 and C127 for S/C got the same bloody set here now dead those parts are bad. Also sorry I read it wrong as I thought you said you brought another and its dead.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              sorry just noticed it was a different psu number
              • Eddy1000
                • Jan 2017
                • 20
                • MyCountry
                no problem!
                thank you. i will check this tomorrow.
                • Eddy1000
                  • Jan 2017
                  • 20
                  • MyCountry
                  Hi!
                  I changed Q216.
                  My circuit has no C525 and no C396. It is a R6 psb (https://www.badcaps.net/forum/attach...1&d=1477225837).
                  How can i test smd caps (C127)?
                  • psdavid65
                    Toshiba 40L1333DEV Vestel 17IPS20
                    by psdavid65
                    Quick Question Please.
                    Is low resistance on gate pin 5 of U202 normal? I have a very very low resistance of 5 ohm on this gate. In diode mode, it looks shorted and beeps. Is this a normal behavior of this FAN6300 IC?
                    All other components on this vestel board have valid readings except for this U202 IC.
                    09-21-2023, 12:29 PM
                  • Jaime Morillo
                    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                    by Jaime Morillo
                    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                    The TV was stuck on the logo and I couldn't access the update menu.
                    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                    The image result was good, but the image is inverted.
                    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                    08-18-2025, 11:38 AM
                  • France_53
                    Vestel tv, how to flip the image?
                    by France_53
                    Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                    05-12-2024, 05:22 AM
                  • ray14324
                    Telefunken LED TV with no standby linght equipped with Vestel 17IPS20 PSU
                    by ray14324
                    Searching the forum revealed loads of issues with this type of power supply board however I could not find a solution to my issue from them. Excuse the "another Vestel" thread
                    The full story was: my Telefunken TV did not have a standby red light after of series of power outages in a couple of minutes. Sadly in my rural city the only technician that fixes TV's is away these days as I cannot reach him by phone. I want to try to have a go at it (with the internet's help).
                    Reading into this symptom the general consensus was that...
                    08-31-2021, 07:55 AM
                  • alltvrepairs
                    Vestel 17IPS20 power supply Q301 runs too hot
                    by alltvrepairs
                    Have just repaired this power supply after 4.7pF 2kv cap burnt.
                    Replaced the following:
                    U300 FAN6300
                    Q301 8N60C
                    R321 10R
                    R311 10R
                    C312 47pF 2KV
                    All Supplies are now fine and TV works great however noticed that the Mosfet is running too hot that barely can leave finger on heatsink for a couple of seconds. I have left TV ON for 18Hrs straight and still works but I know something is not right.
                    Usually a faulty snubber circuit causes this issue. Any known remedies for this common power supply?
                    05-02-2022, 01:46 AM
