Hisense 50H5G - 10-code Flash Error
  • DPenhead
    • Feb 2013
    • 8
    I have something strange going on that I cannot put my finger on, but I wanted to ask this forum their opinion before I keep making this worse. Bear with me, I've fixed several dozen HDTVs and various other electronic devices, but I am not an expert in this like some of you are. I know I made a few mistakes on this TV repair, but if there is a way to salvage this I would sure like to.
    This is where things stand - First off. I am in a hotel on the road for work. You should have that picture in your head... lol.. I purchased a Hisense 50H5G off Craigslist for $25. It had a 10-code flashing power light error that supposedly means there is a loss of power to the set. There is nothing online on any forum I could find that states what the problem is correctly. It's not 'the panel'. It's not the 'AV Main'. It's not the 'PS'. It's an LED shorting out in the backlight. That is what does it. So, I made an LED strip tester out of 2 nails, some copper wire, 2 alligator clips, and some electrical tape. I then snapped two 9V batteries together, connected each exposed lead on the batteries to the alligator clips, and touched the nail leads to the testing spots on the LED strips after removing them from the wiring harness to light each one up. I circled the 4-5 LEDs on 3-4 strips that were not lit, and took out the LED strip that would not even light up. On that strip, I removed the LED that was burnt out and replaced it with a small copper wire and some new solder to complete the connection. I put it all back together, turned on the TV, and it started right up. Beautiful picture, BTW. I then used this TV for about 2 months. One day last week it would not turn on and it did the 10-code error again. I took it back apart and tested the strips in the same way. Two LED strips wouldn't light up this time, including the one I had soldered across the connection. The other one had a new badly scorched LED. There were at this time even more LEDs inside the backlight that would not turn on than there were 2 months ago...but strangely, all on just the right side of the TV backlight nearest to where the wiring comes through from the PS... I circled those. Then, before putting the set back together, I plugged in the TV and hit the power button to double-check the LEDs...panel and speakers disconnected...and a spark shot out of the side of one of the newly purchased LED strips and shorted to the metal backlight casing, which blew out that strip and gave me another 10-code (ARGH!). So, I saw what was happening right in front of me... I have not encountered that before on a previous unit. Out of curiosity and an overall general WTH!, I figured in the moment that I would just snip off the wire leading to that LED strip and splice the wire together with some solder, shrink wrap it, and just bypass that whole strip. I did that. Did a nice job of it too. I then plugged back in the TV and turned it on. It came on for a few seconds just like it was supposed to, then one of the LEDs flashed and the TV went out again back to the 10-code error.
    Now, I have a total of I think 6-7 LED strips with lights that are not lit and everything I touch seems to make this worse. What I think that has happened is that the LEDs are shorting out because the voltage keeps going up every time one blows, so the problem is growing away from the location that is closest to the PS. I then made it worse by removing the resistance that should have been there from the one LED strip I bypassed. Should this be the case, would it fix the issue to buy a new wiring harness for the LED strips, plus replace every strip that has an LED that is burned out, whether it is just a short or just will not light up. Or, is this problem I have encountered evidence of something else that is going on?
    Thanks for everything. I appreciate your time.
    Dave
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Hisense 50H5G - 10-code Flash Error
    Well... interesting story. Here is a condensed answer: The LED back light is current controlled. So here is were things went sour: When you fixed the bad led by jumping it with a wire. What happened is that all the other LEDs on that string got too much power. So you went from one mess into another, because of the same thing all the time.
    What you should have done is to replace the LED with another one. OR you could have taken the bad LED out and jump it with a zener diode. That would have worked too. Whatever you do, don't replace bad LED's with a wire jumper.
    • dskall
      • Oct 2016
      • 2905
      • usa
      You can't just keep bypassing led's. That will kick in the protection. Ether replace the strips, replace the individual led's or bypass with a each with a zener diode.
      • DPenhead
        • Feb 2013
        • 8
        Well, I only bypassed one, but I do hear what you are saying. So, it sounds like everything may potentially be fine if I replace all of the strips to the point that no lights are left out? Any reason that this may be something other than a compounding problem of too much voltage on the remaining LEDs?
        Thanks.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          bypassing even just one, is one to many. Next time turn your back lights down too.
          As it is right now, you would have to replace all the strips and have all the LED's working. LED's don't like heat and too much volts.
          • edugimeno
            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
            by edugimeno
            Hi There!
            I'm trying to help my friend who owns a restaurant be just bought.
            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
            It's stuck using, I guess, the 2 sided tape that comes with the strip
            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
            09-05-2024, 09:34 AM
          • tmhobadcap
            TCL 65S403 Backlight LED Question
            by tmhobadcap
            I got the TV from a friend. He claims that no image but sound from the TV.
            I confirmed that when shine a flashlight on to the screen, I can see the image. And this should be backlight problem.
            I open up the TV and found a few leds failed. And now I am ordering a new set of backlight strips for it.
            But there is something that I do not understand when checking the leds. I do not have an led tester. I only use a bench power supply. I first set the voltage to 3V and current to 10mA. I could not light up the led until I increase the voltage to 12V. I understand most...
            05-25-2025, 11:03 AM
          • edugimeno
            Help findinf LED strips for TDSystems K32DLT1H
            by edugimeno
            Hi There!
            I bought a broken 32" TV today. It has sound but no image. I checked with a flashlight and it was missing backlight
            Disassembled down to the led strips and found this TV has been serviced before. Not sure if it was fixed, worked again for some time, and broke again, or maybe last repair wasn't successful
            Looks like on previous repair, the center LED strip was replaced with a different model, 7 leds in it instead of 8, but when checking LEDS one by one, leds on the center strip were brighter with same test voltage (multimeter in DIODE mode) so maybe the...
            11-05-2022, 03:36 PM
          • smort
            Backlight Polkadarks
            by smort
            Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
            I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had...
            03-11-2025, 12:33 AM
          • x_orange90_x
            Backlight Reflector Modification
            by x_orange90_x
            I am writing this because I came looking for the same information but couldn't find anything. There are certain model tvs that will have 2 or more different backlight strip configurations and there is often no way to tell exactly what you have without disassembling the panel. Twice now I have run into this issue and ended up ordering the wrong sets BOTH times. The previous TV I reordered the correct ones and went on my way. The second one I had no patience for returns or reorders, let alone peeling the brand new strips back out and risk damaging them.
            The number of LEDs per pair is...
            03-12-2024, 08:32 AM
