Samsung LE46C750, power supply BN44-00341A - LOW VOLTAGES
  • jczarniak
    • Oct 2015
    • 179
    Re: Samsung LE46C750, power supply BN44-00341A - LOW VOLTAGES
    Something else:
    - Backlight connected to the PSU
    - Main board connected to the PSU
    - Ribbon between main board and t-con disconnected
    No backlight, TV stayes ON, not rebooting, sound working fine.
    • ducky29
      • Dec 2015
      • 370
      • Europe
      I think that the mainboard is faulty
      • vinceroger69
        • Mar 2012
        • 6714
        can you put the ribbon back on to the tcon and remove the ones going too the lcd panel instead that way should be able to tell if a tcon fault or panel pcb/lcd panel
        • jczarniak
          • Oct 2015
          • 179
          Good point !!!
          I'll check that later today.
          Thank you.
          • jczarniak
            • Oct 2015
            • 179
            I'm still curious why the PSU left for a few hours has got 13 Volt and the backligt is not working.
            After connecting and disconnecting the main board, no more 13 Volt (12.6 instead) but backlight is ON.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              I had a problem similar to this and had to replace the power supply.
              It's a long shot but I would be interested in the result.
              I could bring up the set when I powered PS_ON from 5V using a 1K resistor but not from the mainboard even though the mainboard provided the correct voltage.
              Lift the PS_ON wire from the power supply connector. With the mainboard connected jump a 1K resistor from 5V to PS_ON and see if it boots up normally.
              • jczarniak
                • Oct 2015
                • 179
                Very interested.
                I'll try that today.
                Thank you very much.
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  07-19-2025, 07:14 AM
                • CMCM
                  Russound CA4 Power Supply Repair
                  by CMCM
                  Hello Everybody,
                  Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                  Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                  The outputs marked 12v and 20v are all measuring only 1v.
                  The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                  The capacitors physically look clean (no bludgesor leaks) and...
                  07-03-2025, 01:12 PM
