Toshiba Regza Three Yellow Lights and blowing fuse
  • lowteq
    • Mar 2013
    • 27
    Hello.
    I have a Toshiba Regza 42xv545u that I've been attempting to repair.
    When I first received it, there were no lights at all on the front of the TV. I worked backwards from the AC in and found that a thermal fuse resister R850 next to the bridge rectifier was open. I also noticed that fuse F820 was missing.
    After I replaced R850 I started seeing three yellow lights on the front panel when I hit the power button. According to the manual that means the TV is starting, but it never actually does. I replaced F820 as well and found that it blows immediately, but I still get the three yellow lights.
    The power supply board has model number PE0620.
    Does anybody have any thoughts?
    Craig.
  • petehall347
    • Jan 2015
    • 4437
    • United Kingdom
    Re: Toshiba Regza Three Yellow Lights and blowing fuse
    did someone remove the fuse ?
    if so there is a short ..maybe a fet or 2 . and more damage .
    • dskall
      • Oct 2016
      • 2905
      • usa
      Start following the traces from F820 and test the components till you find the shorted component or components.
        R850 is for inrush current limiter and it is bypassed when the relay next to it is turn on, but if he relay does not come on it will cause the resistor to over heat and go open circuit.
        Fuse F820 is for the PFC Voltage booster output for feeding the SMPS IC Q860.
        Which revision of YOUR board, good clear pictures of your board will help.
        Is it this one?
        Toshiba 75013066 (PE0620C) Power Supply
        http://www.shopjimmy.com/toshiba-750...pply-unit.htm#
        • lowteq
          • Mar 2013
          • 27
          Hello
          It is the C version of the board. I've attached a photo of the board.
          Thank you in advance for any help you can provide.
            Check the resistance between the output side of the fuse 820 and the primary side circuit GND (the negative leg of the main dc filter cap).
            • lowteq
              • Mar 2013
              • 27
              Hello
              Thank you for the troubleshooting advice.
              I've had some work stuff come up so I won't get a chance to take a look until tomorrow, but I will let you know results.
              Craig.
              • lowteq
                • Mar 2013
                • 27
                Hello.
                I've measured the resistance between the output side of fuse F820 and what I believe to be the main filter capacitor (R821 a 150 microFarad, 450V) capacitor. The resistance was 0 ohms, I assume that is bad. I also measured between the other very large capacitor on the board (R820, also 150 microFarad 450V). It was also 0 ohms.
                I've noticed there is a repair kit on ebay for fixing a blown F820 fuse on PE0620 power supplies, but it doesn't say what's actually in the kit. Is this the solution to my problem?
                http://www.cafr.ebay.ca/itm/Repair-K...-/171547395992
                Craig.
                  The fuse feeds the SMPS IC Q860.
                  What is the P/N?
                  • lowteq
                    • Mar 2013
                    • 27
                    It's labeled Q860A on the board. The part number is
                    STR-Z2589
                    86 10
                    Craig.
                    • lowteq
                      • Mar 2013
                      • 27
                      I've done a bit more probing around on the PE0620C power supply board for my TV and I'm finding that all roads lead it SMPS IC Q860A.
                      Should I order a replacement STR-Z2589? Are there any other components I should order with it.
                      My knowledge is limited but getting a bit better.
                      Craig.
                      • corrize
                        A funny fuse story – Lumix LX100 II
                        by corrize
                        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                        10-19-2023, 09:58 AM
                      • jesterace
                        Samsung UE46ES8000 Blown fuse but no other signs of short
                        by jesterace
                        Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                        09-11-2024, 03:14 PM
                      • jshhh
                        Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                        by jshhh
                        Hi guys,
                        I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                        How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                        Anybody know how to remove this type of fuse?
                        (The fuse is toward the bottom of the image labeled F2)...
                        06-17-2025, 01:35 AM
                      • Babbar
                        by Babbar
                        04-12-2024, 01:12 AM
                        Surface Mount Fuses Fundamentals Datasheet
                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                        10-07-2024, 06:07 AM
