Panasonic 50" VT20 arcing at edge of panel to frame
  • heavymachines
    • Mar 2011
    • 1028
    Re: Panasonic 50" VT20 arcing at edge of panel to frame
    Should work.
    • infrag
      • 89
      • australia
      #82
      Well I have an update.
      I bought some more new EMI strip (the first new strip was D shaped instead of flat)
      All up cost me around $50-60.
      Installed it and it works great!
      There is now no difference in potential between the glass strip and the metal frame when the new EMI strip is making contact.
      When I removed the old EMI strip i noticed that it seemed to have deteriorated such that the tape holding the strip down was not holding to the foam shielding very well. The strip came off way too easily leaving the tape behind (which was stuck on extremely well). This was probably the cause of the varying degree of continuity from the strip to the frame and therefore possibly causing my arcing issue.
      I did check some of the other emi strip around the back of the TV and none of them pulled off easily so it seems to be a localised issue at the front of the unit.
      I've managed to watch a couple hours on the TV now with NO arcing whatsoever.
      Thanks for all your replies and for the other 0.000001% of other people in the world with an arcing plasma like mine that was the fix
      • heavymachines
        • Mar 2011
        • 1028
        TA DA. !!!! Good to read.
        • tw2005
          • Oct 2011
          • 6458
          Impressive result and I think you're right. The most original fault I've read of.
          • levcek
            • Dec 2017
            • Slovenia
            #85
            Dear infrag, deal all,
            looks like I've got the same problem with my VT-20. Mine is a 2010-August and last night the arcing appeared for the first time. Exactly like you have described. The arcing sounds scary and the sparkles are not something you wanna see on your precious TV set.
            I'm glad to have found your post and the solution. However opening this beast is another story...
            Cheers!
            • infrag
              • 89
              • australia
              #86
              Cheers!
              Mate you need to take the back off the TV. Then the screws all around the edge tell the front plastic and frame pieces that the plastic face attaches to. Once removed you should look at the metal frame pieces that you've removed that touch the glass. The emi strip is attached to the metal.
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • mecha1166
                Reattaching new edge to edge LCD panel to tv frame - Hisense 55a6g and others
                by mecha1166
                Some new tvs have an LCD screen attached to the outside of the frame with foam tape. These are "edge to edge" as they are called. I am trying to figure out how to reattach an LCD panel back up to the frame. The manufacturer used 3/16 inch foam tape along the top and rh/lh edges. I used a razor blade to separate the panel from the metal frame. The metal frame that the panel is taped to is 1/4 inch wide along the 2 sides and top. I completely removed the residue from the metal frame. There is some residue on the panel itself along the 3 edges, I removed almost all of it using alcohol and...
                06-13-2024, 02:28 PM
                LENOVO ThinkCentre Edge 71 SFF ThinkCentre Edge G630 Specification for Upgrade or Repair
                This specification for the LENOVO ThinkCentre Edge 71 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 SFF boardview and ThinkCentre Edge 71 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-12-2024, 03:36 PM
                LENOVO ThinkCentre Edge 71 ThinkCentre Edge G630 Specification for Upgrade or Repair
                This specification for the LENOVO ThinkCentre Edge 71 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 boardview and ThinkCentre Edge 71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
