Panasonic 50" VT20 arcing at edge of panel to frame
Re: Panasonic 50" VT20 arcing at edge of panel to frame
There is 15V I believe thats meant to go to the A board.......
It start off at about 14.7-8 volts in Standby mode but goes up to 16V while on.
I've checked the voltage on the front of the screen again. When arcing the AC voltage does actually jump around but goes UP not down. The low level DC voltage i measured is actually a minus DC voltage or polarity reversed. Not sure if that helps.Comment
Check your Y mains filter capacitor. It could be leaking to chassis.
Willing to help but I'm no expert.Comment
I've been following this out of curiosity. 20 years or so ago, a friend and I arrived at a customer's house to repair a C-Band satellite dish. We got quite a surprise when upon touching the dish, we got a nasty shock. It took forever to figure out where the voltage was coming from. Turns out, the person's TV had a defective capacitor (or at least that's what he was told later by the repair shop). It was feeding 200V or so to the chasis. The voltage was then traveling over the outter braid of the coax to the satellite receiver and then all the way out the coax to the dish.
Turns out, the voltage was also what had damaged the satellite dish. It caused a failure on the motor that rotated the dish itself.Comment
Attached FilesWilling to help but I'm no expert.Comment
Well to be honest the schematics give me a headache. I'd rather try to find them in circuit... Anyway I've had a look in the PSU for the caps going down to earth and found a few. I have 1 suspect which I've tested before but put back in as it seemed close enough.
Its a 230V 1000uf cap. It tests at 913uf. Initially looking at it seems fine but comparing to the other caps it has what seems like the begininnings of a bulge. Hard to say though. A resistance test returns 515kh reverse polarity and a jumping erratic reading the right polarity way.
Any advice on that or should i just wing it and get another one?Comment
OK one of the legs of each is connected to chassis. Then the other leg of one is connected to neutral and the other has its leg connected to live.
Not exactly sure how to test them but they test the same 0.30uf
Measuring resistance of them registers nothing.Comment
Out of curiosity have you used your meter to measure if there is a voltage between chassis and the frame where you believe it arcing to.
I wouldn't be bothered about the Y caps since they are across the mains so couldn't be leaking to chassis.Last edited by dick_barton; 03-10-2017, 06:12 PM.Willing to help but I'm no expert.Comment
So in the picture attached I measure AC voltage between the strip indicated in red and the frame/chassis of the TV indicated in yellow. Does anyone else get this? I dont expect anyone to actively pull their TV's apart to check but I'd be very interested.
If you take the complete metal frame off the front and just measure between the strip and the chassis/frame of the TV does it make any difference for you?Comment
still trying to get my head around this.... so with statement, and the latest picture, are you seeing any more arcing in this "mode"?... assuming this statement means that the "chassis" and the now unmounted bezel are / were at the same ground potential. In one of your earlier posts, you placed a screw driver on the "chassis member" (I think ) and could cause a arc... is this true still / interpretation correct?Comment
The screwdriver arcing was when I didnt have the metal bezel properly screwed to the frame. Therefore I could get arcing between the metal bezel and the frame with my screwdriver. Does that make more sense?
Since I have made sure its all fastened properly together while testing the frame and metal bezel is all at the same potential.
I can get arcing between the strip I've marked in red and the frame/bezel of the TV though with my screwdriver. Does that make sense too or have I just confused it more for you?Comment
ok thanks for the clarification.
but going from here, you then make this statement ... "However since I made sure the frame was sufficiently grounded to the chassis there is no voltage to measure". from this two questions, what did you do to achieve this? IF you back this out (ie. what you did), does your "screw driver test" still arc?
not sure it matters as I think I see that you indicated "1v" type reading before... which implies some small impedance difference between ground and the frame.Last edited by budwich; 03-11-2017, 11:26 AM.Comment
OK I'll try to draw a usable diagram in paint tomorrow on a computer to explain what I did and where the arcing on the screwdriver was from.
As a side note can I test an A board from a 65" vt20a TV on a 50" vt20a TV and vice versa if the connecters are the same? I'm aware the backing plate might be different but I just want to test it if need be? (I picked up a 65" on Saturday night but it won't turn on with a 10blink code)Last edited by infrag; 03-12-2017, 08:32 AM.Comment
Might need these, foam probably deteriorated inside just a guess what could be wrong ..... http://www.ebay.com/sch/i.html?_from...+foam&_sacat=0Comment
The local component shop has:
Shielding Strip of Ni/Cu Layered Metallized Fiber/Polyether Urethane Foam with Tape.
That should do right?
Edit: Ordered a 1m strip. Cost $15 for 1m. If it make a difference I'll order moreLast edited by infrag; 03-12-2017, 09:00 PM.Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by mecha1166Some new tvs have an LCD screen attached to the outside of the frame with foam tape. These are "edge to edge" as they are called. I am trying to figure out how to reattach an LCD panel back up to the frame. The manufacturer used 3/16 inch foam tape along the top and rh/lh edges. I used a razor blade to separate the panel from the metal frame. The metal frame that the panel is taped to is 1/4 inch wide along the 2 sides and top. I completely removed the residue from the metal frame. There is some residue on the panel itself along the 3 edges, I removed almost all of it using alcohol and...
This specification for the LENOVO ThinkCentre Edge 71 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 boardview and ThinkCentre Edge 71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-12-2024, 03:36 PM
This specification for the LENOVO ThinkCentre Edge 71 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 SFF boardview and ThinkCentre Edge 71 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:36 PM
- Loading...
