Vizio E371vl--Decline to failure (diagnosis?)
  • DoorOfTime
    • Jan 2017
    • 18
    I've scoured this forum and several others for other E-series Vizio TV's and it seems I've got something unique going on here. I think the way this TV killed itself might grant insight into what went wrong, but I'm hoping some of the folks here might be able to confirm my diagnosis!
    I picked up this TV a few days ago off the curb (a promising start, I know!) When I plugged it in everything looked fine--I had full access to the settings menu, IR panel is functional, and all of the buttons worked fine. "Why would somebdoy throw out a perfectly good flat-screen?"
    I connected a computer via HDMI. The only thing notable at the beginning was that the speakers weren't working, though that may have been a configuration problem on the computer.
    When I played a video at full screen the screen started cutting to black at 'random' intervals. This problem got worse the longer it was plugged in.
    Things got weird when I switched to VGA.
    • If a solid black image was placed in the top left corner of the screen (about a 1"X1" square in-set about 1" from the edges), the entire screen was perfectly fine
    • If the same image was completely white, the entire screen went completely dark
    I switched back to both HDMI ports and the same behavior happened there--random screen cutting to black for a fraction of a second before coming back up.
    I left the TV plugged in but turned off for ~1hr, then turned it back on. At this point the HDMI was crashing completely and the computer was losing the TV as an input. When I tried to turn the TV off, the stand-by power cut out altogether. I left the unit unplugged until this morning.
    This morning the screen is exhibiting a "2-seconds to black" behavior. After a hard power reset the stand-by power came back on. When I hit the power button the amber turns white and the "V" logo pops up for ~2 seconds, then the screen goes black and the unit cuts back to amber.
    I visually checked all the caps and tested all of the fuses and resistors, nothing looks fried. Stand-by voltage looks fine, I didn't get to test full voltage (I'll need another pair of hands for the 2-second window to test that).
    Like I said, let me know what you think! I won't color anybody with my own theories yet, but I'll be sure to follow up if I come up with a solution!
  • CapLeaker
    Leaking Member
    • 8212
    Re: Vizio E371vl--Decline to failure (diagnosis?)
    Post a high resolution, straight shot picture of your main board. That set has like a half a dozen different main boards.
    • DoorOfTime
      • Jan 2017
      • 18
      Pictures attached
      • DoorOfTime
        • Jan 2017
        • 18
        Update: Plugged the TV in this evening (~10 hours later) and the unit powered up normally. Factory reset all settings, TV reset successfully.
        Hooked it to a laptop VGA, screen operated completely normally for ~10 minutes. Tried to change inputs and the TV screen dropped back to standby. Turning it back on goes through the startup then drops back to standby again.
        I was thinking this issue was related to EEPROM, but the periodic failures indicate it might be a failed/failing cap, a loose solder joint, or something else that changes during operation (maybe as it gets hot?)
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          try the old hair drier and freezer spray treatment to locate it .. infra red thermometer might help too
          • llonen
            • Sep 2014
            • 495
            • hampshire
            Check the supply rail voltage(s) before and during fault condition, if you have a scope and isolation transformer check the rails for ripple. Morel likely though this is a main board problem, suggest cooling and or heating the various chips and semi conductors and observing the behaviour of the set. (must type faster)
            • CapLeaker
              Leaking Member
              • 8212
              Put some cooling fan on that Mediatek ARM IC and see if that behaves better.
              Next time the unit doesn't boot, freeze the EEPROM with a can of air upside down, then turn the TV on.
              • DoorOfTime
                • Jan 2017
                • 18
                Thanks for the input everyone. I decided to go ahead and re-solder all of the through-hole components on the main board thinking one of those may have cracked when somebody was jamming input cables into the board--no luck.
                I checked every solder joint under magnification and re-soldered anything that looked fishy, but as you can imagine I didn't touch most of the small SM components.
                At this point the TV will pretty consistently turn on and I can access the menu. I can switch inputs when nothing is plugged in, but when I
                1) plug in a VGA while it's on RGB/VGA input or
                --->backlight turns off, white "vizio" shuts off and it goes back on standby
                2) try to switch to HDMI at all
                --->Occasionally gives "no signal" screen. Most of the time input drops back to TV
                Most of the time when it shuts off it will not turn back on immediately. The amber light will blink when the power button is pressed, but the white light will not turn on.
                The issue with inputs happens no matter how long the TV has been on, so it seems that there's something more than a heating or solder problem going on. Do these symptoms seem like they could be bad EEPROM?
                • CapLeaker
                  Leaking Member
                  • 8212
                  the HDMI signal going funky is the Mediatek chip. Look how the trace is going from the HDMI directly to the Mediatek IC.
                  • DoorOfTime
                    • Jan 2017
                    • 18
                    By "going funky", do you think this is a job that re-flowing the board would help or that it's a chip problem and the solution is getting a new one?
                    I was honestly hoping for an EEPROM problem for the learning opportunity! I've had some good discussions around using an Arduino to dump the EEPROM and compare to a previously compiled dump, maybe even modifying some existing Arduino projects to figure out how to re-write it. Can't even trust the E-series to fail predictably!
                    • CapLeaker
                      Leaking Member
                      • 8212
                      try cooling it with a fan first, then reflow, after that either new board or new IC.
                      Not booting may be a EEPROM issue. So maybe it has 2 quirks. So if it doesn't boot, take a can of air upside down and freeze the EEPROM good. Then turn the TV on with the EEPROM frozen. If it comes back, you need either a firmware update or a new EEPROM.
                      • DoorOfTime
                        • Jan 2017
                        • 18
                        This morning I plugged the TV in and turned it on--worked for ~10 minutes. I put a fan on it, insulated it a bit so it would heat up, pressed lightly on the chip--nothing changed its behavior. HDMI input flashing problem got worse over time, then the TV shut off and wouldn't turn back on. I unplugged and hard power reset it.
                        8 hours late I plugged it in and turned it on. It makes it as far as the menu, but when an input is plugged in it crashes. Took it outside for a while to chill--it's under freezing here. Brought it inside and plugged it in, no improvement.
                        Let it warm up a bit (left it plugged in) and turned it on--made it through start-up then blue screened (that's new... didn't know TV's could blue screen)
                        This doesn't sound like a cold solder joint to me... I wouldn't rule it out completely, but it doesn't quite make sense.
                        After hard power resetting and allowing it some down time, I turned the TV on and left it on a TV input--("no channels found"). After ~10 minutes, the TV backlight shut off. Pressing the power button makes the amber light shut off briefly, but it won't turn on.
                        I re-reset it within 30 seconds of going down so the TV was still warm. Turned it on and made it to the menu. Left it on and timed it--10:18 until the backlight shuts off and the TV loses power.
                        Third time I was going to monitor the 12V rail from the power strip. The catch? Power resetting it didn't fix it, it won't turn on. I'll give it some time... it'll be back!
                        • petehall347
                          • Jan 2015
                          • 4427
                          • United Kingdom
                          freeze the eeprom
                          • DoorOfTime
                            • Jan 2017
                            • 18
                            Finally got a chance to freeze the chips. The TV had been unplugged for ~2 days so it was functional when I turned it on.
                            Worth noting--the computer I used to connect to HDMI detected the TV as an output whether or not the TV was turned on.
                            While displaying HDMI on the screen I froze the EEPROM--no apparent change. Shortly after I started chilling the main chip the image cut out, the computer lost the HDMI output, and the TV powered down.
                            So, it looks like this is a main chip problem. I don't have the equipment to reflow at my apartment, and the only thing I can get my hands on is a heat gun which is a bit barbaric.
                            It seems odd to me that the chip would have errors both when it has been on for an extended period or when it is chilled. What exactly would be causing that problem?
                            • petehall347
                              • Jan 2015
                              • 4427
                              • United Kingdom
                              bad soldering or bad internals in chip ..
                              • CapLeaker
                                Leaking Member
                                • 8212
                                You only need flux, solder and a soldering iron to do the Mediatek IC. However I have a feeling that it won't help.
                                • DoorOfTime
                                  • Jan 2017
                                  • 18
                                  So I finally got around to reflowing the mediatek chip this weekend. After being turned off since my last post, I reflowed the VGA side of the chip (which I had solder bridged before).
                                  The TV worked for a good half hour on a VGA input. I tried to switch to an HDMI and the same old behavior cropped up--power cycling, standby ticking off, etc.
                                  I reflowed the remaining sides of the chip and it kept behaving the same way, until... standby power cut out for good. There was a faint but audible crackle (was that there before?) with the TV plugged in, and 125V AC was going over R101 which was unsurprisingly cooked.
                                  I replaced the resistor and unthinkingly plugged it back in for just long enough to see smoke coming off my new resistor as flux burned off.
                                  The only other component that looks like a short is FB603--does anybody know what that component is supposed to be? No marking on it, though it looks like it may be cooked too.
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    Did you try Unplugging the tv from the wall
                                    Hold the power button down on the tv, keep the power button down on the tv and plug the power cord back into the outlet.
                                    Keep the power button down until the tv turns itself on and then off.
                                    • piernov
                                      • Jan 2016
                                      • 4437
                                      • France
                                      Ferrite bead probably, it should measure 0ohm so it is good.
                                      • DoorOfTime
                                        • Jan 2017
                                        • 18
                                        Update:
                                        Looks like I lost the 12V rail but not the 5V rail. Still haven't tracked down my faulty component, open to suggestions.
                                        • howardc64
                                          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                          by howardc64
                                          Problem
                                          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                          Model & Board Pics
                                          Conflicting Spec
                                          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                          https://www.shopjimmy.com/vizio-gj-2k1...
                                          10-10-2024, 01:16 PM
                                        • ipatch
                                          ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                                          by ipatch
                                          i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                                          08-24-2024, 02:36 PM
                                        • bstewara
                                          Vizio P659-G1 Screen Removal / Backlight Replacement
                                          by bstewara
                                          Hi All,
                                          Has anyone had the experience of replacing backights on the “P” series Vizio tv?
                                          Model number P659-G1
                                          This type tv has a very small bezel holding the screen in and I’m not sure how the bezel/screen is assembled. ( I’m hoping the screen is not epoxied to the frame)
                                          Before I attempt this I thought maybe someone on this forum has performed this backlight replacement procedure.
                                          Thanks in advance...
                                          09-26-2022, 10:40 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • FreakyMex
                                          Trouble to identify part (Lunii screen) for replacement
                                          by FreakyMex
                                          Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                                          I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                                          02-17-2025, 01:16 AM
