Eeprom dump thread!
This is a sticky topic.
Hello, can someone check the dump or has the original , thank you
Samsung UE55MU6170UXZG KANT_M_BUILT_IN BN41-02568B BN94-12486N
It responds to remote on and off, but does not turn on 12V power for pmic.Comment
Hello everyone, could someone help me check the bin file for a Samsung UN75MU6103. Ver. FB03. or if you have a working backup, would be greatly appreciated. The Standby led is turned off, still if joystick is pressed or powerd on by remote, it flashes, but nothing happens. All voltages are present and there is no short circuit on the board. Thanks in advance!.Attached FilesComment
Sorry I thought I uploaded it. Here it is. Thanks a lot!!Attached FilesComment
Sorry... i forgot the file...Attached FilesComment
Try it, don’t forget about status register (0x88, 0x42).Attached FilesComment
With this file the led is now red and flashes when sending commands. The tv still doesn't turn on.
The processor heats up even if the tv doesn't seem to do anything.
I read the post about the registers and I hope I programmed the chip well.
Thanks anyway for your support.Comment
hello, I would like to try again to solve the problem of my Samsung TV (UE49MU6220KXZT).
I have a Xggeku T48 programmer, can you confirm that with this device the programming of the bin file and the registers happens all at once?
Or is it necessary to repeat a second time for the status register?
Can someone provide another bin file to try?
Thanks.Comment
Good morning, I would need a good dump file for my samsung ue40mu6400uxzt, I attach the original dump.
Thanks in advance to anyone who can help meAttached FilesComment
Don't forget to set and write the status register (0x88, 0x42) after writing the corrected dump.Attached FilesLast edited by lotas; 01-22-2025, 05:26 AM.Comment
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
by Ancient1Hi
I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
Right distribution board, 2 Flexs, near them:
The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
I... - Loading...
