Good day folks. A neighbour of mine asked me to take a look at her Sony TV, saying that it doesn't tune properly. So I went to her house and sure enough, the TV was "struggling" to tune the channels, meaning it displayed a distorted mess, similar to when the antenna conector is broken or improperly seated - that was my initial though, since the wiring job at her place is pretty messy, with botched connections and kinked wires running all over the show, so to eliminate this variable, I took the TV to our shop where I know the cable is good. This time I also ran a full channel scan to make sure that's not the issue, and sure enough it does "lock" onto the channels, but the picture quality is just....poor, more specifically, it has a double-image effect, making watching something virtually impossible, unless you're standing like 6 meters away from the thing. It's not a problem with the LVDS cable or panel, because the OSD menus and other sources display properly - it's only the cable source that does this, so there must be something wrong with the tuner.
I took the back off and inspecting the area around the tuner, something caught my eye: the cap in the pictures - is it supposed to protrude out of its jacket at the top like that ? I've seen cases where caps did that, despite not being bulged. There's one more cap like that closer to the tuner, you can just about see it in one of the pics. Could this be the cause of the bad signal quality, or should I try replacing the tuner box entirely ? I took some close-ups of the main board here and there. I also see an adjustment pot through a hole in the case of the tuner, how about giving that a turn and see what happens....afraid I'll knock it out of frequency or something and make it worse, that's why I haven't tried it yet
