Sony KLV-37s310A bad quality cable signal (possibly bad tuner/caps)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. A neighbour of mine asked me to take a look at her Sony TV, saying that it doesn't tune properly. So I went to her house and sure enough, the TV was "struggling" to tune the channels, meaning it displayed a distorted mess, similar to when the antenna conector is broken or improperly seated - that was my initial though, since the wiring job at her place is pretty messy, with botched connections and kinked wires running all over the show, so to eliminate this variable, I took the TV to our shop where I know the cable is good. This time I also ran a full channel scan to make sure that's not the issue, and sure enough it does "lock" onto the channels, but the picture quality is just....poor, more specifically, it has a double-image effect, making watching something virtually impossible, unless you're standing like 6 meters away from the thing. It's not a problem with the LVDS cable or panel, because the OSD menus and other sources display properly - it's only the cable source that does this, so there must be something wrong with the tuner.
    I took the back off and inspecting the area around the tuner, something caught my eye: the cap in the pictures - is it supposed to protrude out of its jacket at the top like that ? I've seen cases where caps did that, despite not being bulged. There's one more cap like that closer to the tuner, you can just about see it in one of the pics. Could this be the cause of the bad signal quality, or should I try replacing the tuner box entirely ? I took some close-ups of the main board here and there. I also see an adjustment pot through a hole in the case of the tuner, how about giving that a turn and see what happens....afraid I'll knock it out of frequency or something and make it worse, that's why I haven't tried it yet
    Wattevah...
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sony KLV-37s310A bad quality cable signal (possibly bad tuner/caps)
    Cap looks a little funny. I would pull it and check it. I think cover comes off tuner. Could have a look inside. Try adjusting just mark so you can adjust it back.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      I would try another input and see if it takes care of the double image.
      • R_J
        • 9551
        I know some of the Sony tuners in their crt tv's had bad solder on their ground connections inside the tuner module, also where the leads came inside the tuner could also have poor solder connections
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          I assume you did not fully read my post: the issue only occurs on TV, all other sources are fine, so it's not a display issue.
          Wattevah...
          • R_J
            • 9551
            I have'nt seen any tuner problems in the newer sony lcd sets but theres always a first. I would replace that cap and maybe check others around it before going into the tuner module.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              I wouldn't quite call it "new"....it's not even digital, but whatever
              Wattevah...
              • R_J
                • 9551
                well I did'nt say it was new I said newer as in not a crt tv which had the tuner module problems. when I see caps next to coils like that I suspect they get quite warm and would be my first suspects.
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  I returned the TV anyway, so it's too late now...thanks anyway.
                  Wattevah...
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    I read it but was a little confused as to what sources were, I call them inputs. Most likely it was in the Phase Lock Loop section of the tuner.
                    • CapLeaker
                      Leaking Member
                      • 8195
                      Too late now I guess, but I would have ran the TV for a little while to see if those suspected caps got hot. And of course I'd have checked the caps with the oscilloscope.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        Technically, I COULD get back the TV to work on it so more, since it belongs to someone who lives in the same building as our shop, but it's large, heavy and takes up too much workspace, so she'll just have to stick with a decoder box for now....
                        Wattevah...
                        • AstutePauciloquent
                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                          by AstutePauciloquent
                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                          11-23-2023, 11:02 PM
                        • CyberPhoenix
                          Issue with picture quality of Sony bravia TV
                          by CyberPhoenix
                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                          01-22-2024, 02:08 AM
                        • kramer826
                          Sony KD-55X8500F service manual BL-on signal
                          by kramer826
                          Hello , I am looking for a service manual or schematic information to find out where to measure BL-on signal backlight on signal from the mainboard.
                          I have a tv which works fine and a spare main board that Ii am trying to fault find that is not turning the backlight on,6 flashes.
                          The backlights work ok with other main board.
                          Thankyou for any information
                          07-14-2023, 03:50 AM
                        • benspawn02
                          Anthem MRX500 - no sound. R2A15218FP issue??
                          by benspawn02
                          Dear Electronics Experts:
                          I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                          08-12-2023, 04:46 AM
                        • Carlos#2003%
                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                          by Carlos#2003%
                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                          02-15-2024, 07:52 PM
