I have just installed a Main board, and it cured the sound problem. On this set you have to pair the remote to the set. I cannot get to the menu to reset to factory defaults. I have another Vizio remote and a programable remote, but menu sends me to the internet apps. Anyone have any ideas? maybe a jumper??
Vizio XVT423SV
Re: Vizio XVT423SV
https://support.vizio.com/s/article/...roubleshootingWilling to help but I'm no expert. -
Re: Vizio XVT423SV
Hold down the rocker (power on) and connect the AC; wait until you see the "V" on the screen then release.
This, to the best of my knowledge, is factory reset settings for the family.
(you can also try it from the config menu, but as I understand this is better)
2) You can just replace the whole EEPROM on the main and all settings will get replaced along with it.
On a side note if you do not need your old main board we'd be interested in buying and fixing it.Comment
TCL LED TV Service Menu Code
LG LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
Assuming...7 Photos -
by JaquesPrattI have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable.... -
by cstoutHello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
I can't find any schematics... -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... - Loading...
