Sansui LCT32SD not switching on
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Hi guys,
    I need help determining the value of two components on the power supply.
    I've included a photo of the pcb with the components high lighted.
    IC6 = L6599 Hv resonant controller Turquoise square. Vcc is pin 12 (self limiting).
    IC3 = opto couple Yellow square.
    Trans 5. 2SA1815 (on top of pcb) marked Green. measured okay.
    Trans 6. 2SA1015 (on top of pcb) marked Blue. Short/ replaced.
    Diode 9. (on top of pcb) marked yellow. okay.
    R30. determine value. marked Red. burned beyond recognition.
    Zener diode determine value. marked Red. short No inscription.
    I tried a 1 ohm (feed resistor?) in position R30. and 5v8 for the Zener.
    But set wouldnt switch on and both slowly got hot and burned black.
    I tried electro tanya for the diagram, but no luck.
    I'm hoping one of the guys on BADCAPS with design knowledge, might be able to determine the values. Thanks.
    I forgot to say the 5v stby is there, and the psu-on does appear when pressing standby button, with led going from red to green. I reckon IC 6 isn't getting a supply, so it cant drive the transformer responsible for generating the 9,12 & 24v rails
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Re: Sansui LCT32SD not switching on
    Anybody?
    • Grunder
      • Jan 2016
      • 323
      • south africa
      Hi Guys,
      Took a chance and done a little experimentation.
      Replaced the burned resistor with a 120 ohm 1/4 watt resistor (photo 1)
      Replaced the shorted zener with a 12v zener.
      Set now switches on (backlights on), and working perfectly! (Photo 2)
      I guess the resistor was a limiting resistor, and the first attempt using the 1 ohm allowed too much current through, burning up the zener.
      I now get 12v across the zener in standby. 11.3v when the set is running.
      I now get 10.7 volts supplied to pin 12 (Vcc) on the Hv resonant ic.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        What was IC7's part number?
        • Grunder
          • Jan 2016
          • 323
          • south africa
          Hi Dick,
          You might not have seen my recent post (3 min before your reply).
          I did manage to get the set running.
          I didn't identify IC 7, I also suspected IC 7 got damaged. Set has been closed up.
          Thanks response.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            Hi, I did see your post but was thinking that the data sheet for IC7 would give typical component values to check against what you used.
            • Grunder
              • Jan 2016
              • 323
              • south africa
              Hi Dick, quite right, checking the specs on that ic(7) would have given me a better idea of what voltages to expect in that area.
              She's running now with no heat or burning of the components fitted, if she comes back (hope not), I will investigate further.
              Thanks for the input.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
                • caspian
                  What Zener Diodes on a Linear Power Supply
                  by caspian
                  Dear members,
                  I have a linear variable power supply with unknown brand name that I used for voltage injection.
                  Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                  In addition, I discovered that its zener diodes are defective.
                  I can replace the burned transistors.
                  But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                  Therefore, I cannot replace the zener diodes.
                  I do not want to test the zener diodes in a test circuit to discover their model or value.
                  no schematics are available...
                  05-26-2025, 12:38 PM
                • nev1001
                  What zener diode might fix the sound on Maestro Mayhem gaming chair?
                  by nev1001
                  Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                  The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                  It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                  I think an issue could be a zener diode (or capacitor) which has shorted out.
                  The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                  04-17-2025, 05:09 PM
                  by sam_sam_sam
                  After all of...
                  07-13-2024, 08:14 PM
