Panasonic Viera LED TH60CX700A - Sound / Backlights Working - No Picture
  • dandan556
    • Jun 2020
    Re: Panasonic Viera LED TH60CX700A - Sound / Backlights Working - No Picture
    1) So you get the same result when one cable between T-CON and the LCD panel is connected one at time and you do have 12V at both ends of the T-con fuse, correct?
    Yes, exactly the same results.
    2) If the above is true then you need to check the resistance of the MLCC on the tab bonding boards as suggested. ACEMAN never posts back what he found.
    Thanks I'll check this when I get chance, which side is the issue most likely to be on? The side that doesn't change once unplugged or the one that goes bright white?
    • iglitare
      by iglitare
      09-04-2025, 07:13 AM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • FZG
      Panasonic AG-1000B VHS player with bad picture quality
      by FZG
      Hello!
      I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
      Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
      I want to know, is this something that could be solved by recapping or is the video head likely gone?
      Also, what mechanism is this?
      Any feedback is appreciated!...
      05-06-2024, 07:16 AM
    • DXseekerMO
      TCL 55US57 backlights, no picture.
      by DXseekerMO
      So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
      The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
      Power Supply, main and T-CON board are working.
      Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
      Unhook FFC from left side...
      09-18-2021, 03:56 PM
    • Bazfletch3
      Panasonic TH-65FX800A backlight LED's working but picture is very dark
      by Bazfletch3
      Hi all
      While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
      I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
      From there I envisaged that the backlighting wasn't working, however...
      01-08-2024, 10:18 PM
