Re: Panasonic Viera LED TH60CX700A - Sound / Backlights Working - No Picture
Yes, exactly the same results.
Thanks I'll check this when I get chance, which side is the issue most likely to be on? The side that doesn't change once unplugged or the one that goes bright white?
1) So you get the same result when one cable between T-CON and the LCD panel is connected one at time and you do have 12V at both ends of the T-con fuse, correct?
2) If the above is true then you need to check the resistance of the MLCC on the tab bonding boards as suggested. ACEMAN never posts back what he found.
