Tab bonding repair
  • jmh474
    • Aug 2016
    • 46
    • uk
    Tab bonding repair
    Hi all again, so iv a little problem I asked someone to help me repair a TV with me and he pulled off one of the ribbon cables which connect to the LCD panel, I'm hoping there is away of repairing the tab bond, thanks for any help
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Tab bonding repair
    Tab bonds are not user repairable at this time and can only be done using highly specialised equipment.
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • Rubenlily
      Quick question about the ribbon
      by Rubenlily
      Hey,
      So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
      When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines...
      08-17-2023, 11:09 AM
    • KYBOSH
      Samsung QN75Q70TAF - Problem ON or WITHIN the Display??
      by KYBOSH
      Came across a 75" QLED TV with restart-backlight no boot and it was headed to the dumpster. Asked the owner to let me have a crack at it. They said the TV went out during or soon after a thunderstorm. I noted this but didnt out too much stock into it as it could have been anything.
      VERY big TV and i was worried about the display cracking during the moved as well as the repair but it was alright as i try very hard to handle with care.
      In the video (zip file) you can see' as the TV tries to start up, tbere are a lot of gaps in the backlight so I immediately suspect...
      10-19-2023, 05:33 PM
    • Scincidae
      UN70NU6900FXZA Won't Boot Unless I Temporarily Disconnect Right LVDS Ribbon
      by Scincidae
      I recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
      I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While...
      04-24-2022, 06:00 PM
    • kca
      50" LG tv with a slightly torn ribbon cable ~ Any repair method?
      by kca
      Hello all ~
      I have this LG 50" plasma tv that is in perfect working condition except for the fact that it has one (and only one), singular torn ribbon strip on one (and only one) of the 8 orange ribbon connectors that feed from the Y-Sustain to the screen itself.
      So, as a result, there is one, singular thin black horizontal line that goes across the entire screen. Distracting enough to render the picture unwatchable for all intents and purposes.
      What I am wondering is if anyone out there has ever had any success in fixing one of these ribbon cables...
      09-24-2020, 02:07 PM
