Panasonic 50" LED TV TX-L50B6B BLINKING
  • pyromyst
    • Dec 2016
    • 5
    • United Kingdom
    Woke up on xmas morning to find my 2 year old panasonic tv just blinking at me.
    Whole screen blinks at one second intervals.
    Please help.
    Please see attached.
    i am getting a steady 5.2 volts at the standby pin with all leads disconnected.
    the centre pin on the main board to the Tcon board is fluctuating from 1.1v to 1.25v.
    i get 107v fluctuating to 85v on the outlet from the LED driver board.
    Ihave not yet removed any further panels to check LED's
    Many thanks in advance
  • zomi
    • Nov 2011
    • 512
    Re: Panasonic 50" LED TV TX-L50B6B BLINKING
    You have one or more blown leds, its nearly always the leds on this particular set.
    Done about 10, always been leds
    Some just done come on
    Some come on and no display
    Some come on and flicker
    • pyromyst
      • Dec 2016
      • 5
      • United Kingdom
      Many thanks Zomi.
      After stripping the TV down i found 3 rows of LED's not flashing and 3 rows that were.
      i swapped out 2 good ones for 2 bad ones and got those to flash too. but still only the centre 3 strips flickered.
      After swapping the bad top strip (L1.R1) with the centre (L1.R1) the outer 3 flashed.
      so it leads to one strip of (L1.R1)
      will report back if fixed, many thanks for your help
      • zomi
        • Nov 2011
        • 512
        if you have a multimeter
        then set on diode mode and test each led sep
        you just have to scratch the paint a bit
        https://www.youtube.com/watch?v=eEJoPCa7Kt0
        then you can see whats what.
        Some times they do go in a bad way and take out the inverter
        • signal.quest
          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
          by signal.quest
          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
          03-17-2024, 10:14 AM
        • riparo
          Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
          by riparo
          Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
          I attach a link to download the service manual, thank you for anyone who can help me
          https://tel-spb.ru/download/?brand=P...0E_LA73.rarโ€‹
          01-11-2024, 12:35 PM
        • SLB007
          Panasonic TX-32C300B stanbye light blinking 13 times
          by SLB007
          I get no image nor backlight, standby light blinks 13 times then stops. Any clues what it could be no evidence of damaged components
          11-02-2025, 04:08 PM
        • BigPete
          Panasonic Heatpump Dryer Repair
          by BigPete
          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
          Unfortunately the whole machine has to come apart to fix it.
          I have...
          11-01-2025, 06:40 PM
        • Pipolups
          Corsair K70 LUX RGB dying LEDs
          by Pipolups
          Hi there !
          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...๐Ÿ˜…
          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me ๐Ÿ™„...
          10-08-2024, 11:58 AM
