Samsung PS64D8000 switch on problem help please
  • Maxwell4321
    • Feb 2016
    I have a PS64D8000 that will not come out of standby
    I begin by checking for Vs and I find 5vdc on it at all times (should be 217) This is present in both Standby and On.
    Power off and I then put the meter on ohms and check for short from X & Y boards by measuring resistance between Vs test point and GND and disconnect the X board, no changes to resistance reading @50k, disconnect Y board and again no change so still at 50k.
    From this I assume that the X and Y boards are not killing the Vs but to be sure I powered up with X&Y disconnected, now this particular model will shut down the SMPS immediately if X or Y are disconnected on power up but if you attach volt meter to Vs test point before power on you should be able to quickly see Vs go to full voltage then drop back to zero but I get nothing apart from a few mV.
    I now move onto the logic board which is powering on ok and test the Ps on and all is good at 3.3v so test the Vs on signal in standby and its at 0v (as it should be in standby), bring it out of standby and it goes briefly to 3.3v then quickly back to 0v,
    I do not know if it should remain at 3.3v or not ??? so any help with that would be appreciated.
    There is a green led on the logic board that flashes on and off every 3 seconds but I don't know if this means everything is ok or not.
    Main board is also powering up ok.
    I cannot test for Vsc or Ve as they are generated by the Y board from the supplied Vs
    I am leaning towards a faulty SMPS at the moment (mainly because of the constant 5v being present on Vs and no Vs reading with X&Y disconnected) but would appreciate any other ideas/input please.
  • Maxwell4321
    • Feb 2016
    Re: Samsung PS64D8000 switch on problem help please
    Ok problem solved, dry joint on SMPS for one of the transformers
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Good job
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • mrautom8
        Samsung TV UN75H6350AFXZC main board schematics?
        by mrautom8
        Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
        Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
        While relay is on, all voltage rails are present and steady (scoped) on main board.
        I love a good logic puzzle but getting lost without any schematics.
        No shorts on ANY capacitor main board.
        Thermal camera shows 3.3V inductor getting warm instantly but...
        10-19-2025, 06:32 PM
      • stylishconsultant
        un60j620dafxza - Samsung No Display Problem
        by stylishconsultant
        Hi All,
        Need help.
        I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
        So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
        problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
        might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
        09-04-2024, 03:26 AM
