TNPA5335 7 blinks continues after "fix"
  • Logan_c
    • Sep 2016
    • 11
    • US
    I received a repair kit for the TNPA5335BA board and while I don't have the skills I have a buddy who does. The kit (https://www.shopjimmy.com/panasonic-...tc-p55gt30.htm) I ordered from shopjimmy and all the parts were installed. However Q621-623 are the original 30F131 on the SC.
    After the repair I am still getting 7 blinks.
    I have pulled the 3 boards out and when I ohm out the replacement FGB20N60SFD on Q401-Q403 (measuring the outer legs) I get about 47 ohms. I also get the same on Q421-Q423, also the Fairchild replacements.
    This is what I get on:
    Q621--- 25.8 ohms (original 30F131)
    Q622 --- 6.6 ohms (original 30F131)
    Q623 --- 25.6 ohms (original 30F131)
    Does this seem correct, or suspect?
    I did have a couple bad IC's on the SU board, which I have run a continuity test across SU1 and SU2 since two IC's were replaced and I no longer get shorts like I had before.
    Since I am still getting SOS7 I suspect the SC board. Maybe it is simply Q621-Q623? Do the above measurements seem to indicate Q621-Q623 are bad?
    Also, I get 40 ohms on Q661, if that means anything...
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: TNPA5335 7 blinks continues after "fix"
    Check everything for shorts and before you install it, re-flow all the screw holes, top and bottom. Check the small driver Ic's as well( the 3 legged ones).
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      I just remembered that I fixed two of these. One for a 55" and one for a 50".
      The one for the 50" was no problem, but the 55" had a bad q600 and a bad part marked DAF 3....something? I should have taken notes on my repairs. On the 55" i also had a bad upper buffer board. Check other posts on how to check SU and SU boards. Hope this helps.
      • crt man
        • Mar 2013
        • 106
        • England
        Do a search, there is lots of threads on repair of this board.
        Q621-3 seem short to me
        Alan
        • Biruslapio
          Panasonic P58V11B 8 and 12 blinks error "fix"
          by Biruslapio
          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
          04-13-2021, 07:13 AM
        • narf
          Epson EB-U42 projector / Caps with 0.7 ohms ?!
          by narf
          hi all,
          first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
          i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
          what i've found so far:
          - the PSU does its job and supplies 12V to the mainboard via the connector.
          - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
          - not far away, there's the first cap with a resistance of 0.7 ohms....
          07-02-2024, 03:53 PM
        • Nairolf
          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
          by Nairolf
          I have a Samsung DM32D display.
          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
          Here’s what I have tried so far:
          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
          From these tests, I suspect the problem might be on the mainboard. Could anyone...
          08-24-2025, 03:47 AM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • Taurus12
          Optiplex 3050 micro 2 blinks followed by 3 blinks issue
          by Taurus12
          Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
          I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
          i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
          Any recommendation on what I have to do next? Thanks in advance
          06-10-2025, 05:05 PM
