dell U2312hmt flickering
  • Cyanide
    • Jun 2013
    • Belgium
    II have a defective dell U2311hmt unit. The monitor is older than 3 years and has no more warranty.
    The screen starts flawlessly, but there is very noticeable flickering in the left part of the screen. The monitor has LED backlighting. I opened the monitor and looked at the prints. At first glance, everything looks normal: no burn marks, nor bulged caps.
    Off course, this doesn't mean that the caps are all fine, but before I replace them, I wanted to ask if anyone has experience with this monitor and knows what is wrong?
    EDIT: this needs to be placed in computer display subforum, can an admin change the thread. Sorry for posting it in the wrong subforum.
  • keepread
    Dell monitor PSU vs Dell laptop PSU
    by keepread
    Hi there!
    Someone gave me their old monitor, it's Dell S2715ht.
    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
    10-30-2025, 04:45 PM
  • Borse2008
    Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
    by Borse2008
    Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
    I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
    • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
    • There’s
    07-15-2025, 04:55 AM
  • reessi
    ACER BM320 Monitor - Horizonal Flickering Lines After a While
    by reessi
    The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
    They are black on the right and gradually fade to nothing on the far left.
    They start either after 5 mins or up to 2 hours after so annoying for testing.
    They flicker continuously very fast! With a slight pause milli-second every second.
    Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
    I tested each half by removing the first the left flex from...
    06-03-2025, 09:58 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
