dell U2312hmt flickering
  • Cyanide
    • Jun 2013
    • Belgium
    II have a defective dell U2311hmt unit. The monitor is older than 3 years and has no more warranty.
    The screen starts flawlessly, but there is very noticeable flickering in the left part of the screen. The monitor has LED backlighting. I opened the monitor and looked at the prints. At first glance, everything looks normal: no burn marks, nor bulged caps.
    Off course, this doesn't mean that the caps are all fine, but before I replace them, I wanted to ask if anyone has experience with this monitor and knows what is wrong?
    EDIT: this needs to be placed in computer display subforum, can an admin change the thread. Sorry for posting it in the wrong subforum.
  • Borse2008
    by Borse2008
    • There’s
    07-15-2025, 04:55 AM
  • reessi
    ACER BM320 Monitor - Horizonal Flickering Lines After a While
    by reessi
    The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
    They are black on the right and gradually fade to nothing on the far left.
    They start either after 5 mins or up to 2 hours after so annoying for testing.
    They flicker continuously very fast! With a slight pause milli-second every second.
    Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
    I tested each half by removing the first the left flex from...
    06-03-2025, 09:58 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
    by momaka
    03-15-2023, 10:17 PM
