LG 42LC3R-zh
  • redriddick
    • 93
    • Ireland
    LG 42LC3R-zh
    Hi Guys,
    A friend of mine just gave me one of the above to have a look at.
    The screen randomly has all coloured lines running through it but if you turn it off and back on it is fine again for awhile.
    When this happens I tried to switch the source from hdmi to tv and when the snow appears the lines go.
    Then when I switch back to hdmi you can see the faint lines but after a few minutes they disappear and it is fine again.
    Would this be Tcon or main board problem or panel.
    Thanks in advance.
    Redriddick
  • Diah
    • Feb 2013
    • 6392
    Re: LG 42LC3R-zh
    when you switched from HDMI to TV or any at the TV, did you used the remote or pressing on the TV control panel ?
    • redriddick
      • 93
      • Ireland
      Re: LG 42LC3R-zh
      I used the panel at the side of the tv!!
      • Diah
        • Feb 2013
        • 6392
        Re: LG 42LC3R-zh
        also when this fault show to you try to click on the TV side or up and down smoothly to see if the lines disappear.. if this happen then you have Tab bound . here over the forum many user did video how to fix it.
        • redriddick
          • 93
          • Ireland
          Re: LG 42LC3R-zh
          CLick the buttons up and down to change channel????
          Is that what you mean???
          • Diah
            • Feb 2013
            • 6392
            Re: LG 42LC3R-zh
            sorry for the bad typing . with hand hits the TV side smoothly or with finger push the front down forward the screen. if the coloured line changed or disappear.
            • redriddick
              • 93
              • Ireland
              Re: LG 42LC3R-zh
              No problem I will try that today!!
              • redriddick
                • 93
                • Ireland
                Re: LG 42LC3R-zh
                No joy with that!!!
                Something else I noticed:
                I have my laptop connected to the tv via hdmi,when the screen goes white with the coloured lines if I disconnect the hdmi and reconnect the tv displays as normal!!
                Surely it would not be a tab bond issue if it does this???
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Re: LG 42LC3R-zh
                  Tap the mainboard around the HDMI sockets to see if there's a poor connection such as the shield being poorly soldered. Also check all the screw holding down the mainboard are firmly in place and not loose.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Re: LG 42LC3R-zh
                    Could be bga solder issue on the cpu, or even bad solder joints on the hdmi ports.
                    • redriddick
                      • 93
                      • Ireland
                      Re: LG 42LC3R-zh
                      I think it maybe the hdmi ports as moving the connection up and down brings the picture back.
                      Now can these be resoldered???
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Re: LG 42LC3R-zh
                        Yes use flux on the pins, and touch them with a timed iron or you could flux the pins and use hot air and reflow it that way.
                        • redriddick
                          • 93
                          • Ireland
                          Re: LG 42LC3R-zh
                          Well guys I tried to reflow the hdmi ports at the weekend and it did'nt work.
                          Maybe I made a balls of it I dont know but might try it again tomorrow night.
                          • redriddick
                            • 93
                            • Ireland
                            Re: LG 42LC3R-zh
                            well i tried the scart inputs and had the same problem so does this mean its the main board
                              Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                              This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-06-2024, 05:30 AM
                            • Raulnn
                              Xiaomi L55M5-5ASP fine lines on the panel uniform
                              by Raulnn
                              Good afternoon! Does anyone know how to remove these lines? They are very fine lines at the bottom of the panel. I have 2 identical panels, and I have even thought that this brand has this lattice format, although I highly doubt it.
                              The photo from the YouTube app is where it is best seen.
                              thanks in advance....
                              01-28-2024, 10:30 AM
                            • madan1
                              Cisco catalyst 2960c POE
                              by madan1
                              Hello everyone.
                              Got a catalyst 2960 from the usual scrapyard - ebay.
                              It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
                              Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
                              Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
                              The switch fails to boot due to the following POST error:...
                              12-19-2024, 09:34 AM
                            • howardc64
                              by howardc64
                              07-24-2025, 05:17 PM
                            • Natob82
                              Micro Momentary Push Switch?
                              by Natob82
                              Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                              12-21-2022, 05:22 AM
