37ld465
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    37ld465
    Have a TV with broken screen ...
    Any one knows where to find a OK screen in EU, it must not be new???
    thx
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • siergiej
    Try to find new screen for ANBERNIC RG 28XX
    by siergiej
    Hello
    I have ANBERNIC RG 28XX small toy but give a lot off joy. But it fell from table and screen break
    Screen is 2.83 inch IPS 640x480 with 39 pin and making YLM-28F1002-A1.
    for several day I try to find this same screen for replacement. So far i'm unable to do it.
    Please help me !!!
    09-08-2024, 02:26 AM
  • corrize
    Resonator - quartz broken - how to find the same (same frequency) ?
    by corrize
    Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
    I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
    I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
    I'm searching another one for compare…
    Do you have an idea or another way for find the frequency of this resonator please ?
    (I did not found the manufacturer of this component ? And I did not found the...
    03-27-2025, 09:20 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
