LG LN5700 logo flash then dark screen
  • robledjl
    • Nov 2016
    • 30
    First of all thank you for whoever reads this post. I have to say I'm not a professional but I do have some experience with basic electrical work, enough to not get myself zapped lol so after spending four days reading threads and looking at videos I came to a conclusion that my TV as many others have a burned LED, well to my surprise after disassembling the screen all led's turned on even one that just by looking at it you would think that it's no good. I am attaching a picture to see what you guys think. Like I said all turn on just fine although one is still in question once you see the picture. Any advice will be greatly appreciated.
    As you can see it looks like the cover burnt out or cracked.
  • robledjl
    • Nov 2016
    • 30
    Re: LG LN5700 logo flash then dark screen
    Well just in case anyone is still looking at this post... I kept looking at the led on the picture above and still searching online for more solutions. What I've noticed is that someone had previously repaired that led, I realized the solder work that it was done and how they used a glue gun to try to hold the led cover, which it didn't work because I found the cover on the corner of the screen. In short... My assumption is that someone tried to fix it before and I'm not sure if they solder it wrong... And further suggestions would be greatly appreciated . like I said all turn on, there are no bad led but turns on and then off.
    • robledjl
      • Nov 2016
      • 30
      **UPDATE ** well further inspection it looks like the led although poor soldering job it works, I turned the TV on and it actually stays on the remainder of the time until later on when I turn it off and on that's when it flashes, all led stay lit.. I also checked the voltage in regards to the table listed on the power board and they are all good. I'm confused now, I was really hoping it was a bad led but I think I can rule that out, anyone out there that can lead me in the right direction?
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        more info,you clearly bought it used (previous repair). Did it work for awhile and then quit or it has been doing the 2 sec to black right away.
        First guess,without any info would be that soldered in led has different specs and triggers the fault button
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
        • robledjl
          • Nov 2016
          • 30
          Thanks first of all for your reply. It was given to me for free. They told me it turns off as soon as they turned it on, once I brought it home it worked just fine until later on when I tried to turn it on again that's when I realized what they were talking about. I could still see the menu very slightly just like the flashlight test. That's when I started reading a lot until I cracked it open and realized all led were working just fine although from the looks of it, it had been repaired before.
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            Is this the 42"?
            I'd say this is your best option:
            https://www.shopjimmy.com/lg-lc420du...ps-1-board.htm
            These models and many other LG led tv's are plagued with failing led's.
            9 out of 10 times I get a lg here it's the led's . Turning backlight down as much as you can bare will increase life by miles.
            • robledjl
              • Nov 2016
              • 30
              This is the 47". Do you think I still need to replace the led strips even though they all turn on even the one that I thought was burnt on the picture?
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                I would perhaps test the amperage to the led's per line first.See if one line is giving itself away by drawing more then the others.
                • martino
                  Not so "senior"
                  • Aug 2013
                  • 997
                  • canada
                  Found something interesting for you
                  This guy is worth watching!!!
                  https://www.youtube.com/watch?v=Bf5T2wwtydY
                  • robledjl
                    • Nov 2016
                    • 30
                    Oh man trust me I've watched his video quite a few times lol the amperage seems to be fine, now that I flipped the TV over to check the strips it seems to stay on, I've turned on and off the TV via the power button on the side and it functions perfectly... I'm really confused now???. Thanks for your replies once again
                    • robledjl
                      • Nov 2016
                      • 30
                      ... Another thing I just noticed, so far the led's stay on. I left the TV on in the garage to see if they will stay on for a while, well it seems like after 30 minutes or so it turns off, I'm wondering if it has a setting that makes it turn on if there is no signal? I then turn it back on and it stays on. I'm still puzzled as to my original problem??
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        It will shut off on the no-signal timer.
                        What voltages are you getting on the 2 test points for the LED's?
                        "Amperage seems to be fine".....AS in you measured it? If you loop your multi meter into the circuit,you can clearly tell if all trips are pulling the same or if there is one that draws border line enough to trigger fault.
                        Sometimes by staring long enough at the led's you can see one or two that are a slight different brightness,those would be suspect.
                        Did you take a super close look at the soldered led? Crappy soldering maybe intermittent good or bad contact?
                        Knowing the bad rap this model has for it's backlighting I would try the above suggestions as I still believe it to be a led failure. (a fun one as it is not obvious into what strip is teasing you,lol)
                        • robledjl
                          • Nov 2016
                          • 30
                          Hey Martino! Thanks again for helping me out. I'm not sure if I wasn't understanding you right but I took some pictures to maybe help you understand what I did. Now I'm not a professional but I try to fix things. Lol I tested the + pins as shown on the picture, I get a reading of 76.5 on both with the TV on. I also took a picture of the solder it had been done before, what do you think? Did you wanted me to read the points on the actual strip?
                          • robledjl
                            • Nov 2016
                            • 30
                            can anyone look at the picture of the LED that had been solder and see if it looks good or should I try to flow it better? Like mentioned before...this TV had been previously repaired before it was given to me. thanks
                            • martino
                              Not so "senior"
                              • Aug 2013
                              • 997
                              • canada
                              Did you test like in the video,from 1:20 to 2:20.?
                              • robledjl
                                • Nov 2016
                                • 30
                                OK Martino, I just got home and played the video again and followed it like you mentioned, I don't have a fluke with a min max option but this is what I got... Right side 058.2 and left side 37.5 but it was not steady it would fluctuate. ???
                                • robledjl
                                  • Nov 2016
                                  • 30
                                  Does anyone know if these readings are wrong? Bad?
                                  • robledjl
                                    • Nov 2016
                                    • 30
                                    Are you still around Martino?
                                    • martino
                                      Not so "senior"
                                      • Aug 2013
                                      • 997
                                      • canada
                                      ya,been busy.
                                      I'd say both sides should read equal. I have this same model here,screen is gone but i used it as a donor for two others. I will make the backlight complete and measure what mine does.Will report tomorrow what my readings are.
                                      • robledjl
                                        • Nov 2016
                                        • 30
                                        You are awesome brother! I am close to taking it to the recycling center but I wanted to make sure there was nothing else I could do... Im just not too savvy in TV 's. I really appreciate your help even though you are busy. Thanks once again.
                                        • Yolojays
                                          HP Zbook Flash Screen Logo question
                                          by Yolojays
                                          Hello everybody,
                                          I cleared the Bios password on a HP ZBook 15u G3 Laptop (i5-6200U​) using HPUnlocker tool. My question is, the laptop has a Custom Boot Logo and can't find a way to restore it to the original HP logo. Anyone by chance know a way to do it?
                                          What I tried and checked:
                                          -No custom logo option in bios
                                          -updating the bios did not help
                                          -Hp client management library method id not work
                                          -ereplogo utility di not work
                                          Thanks in advanced....
                                          03-15-2024, 10:04 AM
                                        • abajor
                                          A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                                          by abajor
                                          Having this very weird issue.
                                          The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                                          I swapped with a working screen from an A2141 waiting for parts.
                                          The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                                          The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                                          04-27-2024, 01:37 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • howardc64
                                          A1312 (27ā€ iMac 2009-2011) A1407 (Thunderbolt Display) A1316 (Cinema Display) Display Black Screen Repair
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
