50pm680t not turning on
  • thuss
    • Jul 2012
    • 321
    Hi
    My mates tv wont turn on. Standby light turns on and is on constantly but when the remote is pressed the standby light blinks once and goes back to red.
    I've disconnected the psu from the main board and attached 2 X 0.25watt resistors 330ohm (as per bdacaps page 2 Re: LG Plasma 50PA5500) and disconnected the lvds cribbon from the tcon board (with a linkbetween ext and auto gen) hoping to get the patterns but the tv still didnt turn on.
    Has anybody repaired one of these power supplys before? (I checked the green cap and its reading 22ohm)
    Any help would be appreciated
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: 50pm680t not turning on
    Unsolder and lift one end of the green cap and measure again. It should read OL when tested.
    • thuss
      • Jul 2012
      • 321
      My mistake I meant 22uf.
      The green cap has the following written on it FL 1.25KV 223H S'M36 so I assume the above reading is fine?
      • thuss
        • Jul 2012
        • 321
        Anyone?
        When I switch the tv on Im getting 17v etc for a split second, the main board flashes green and then back to a red standby light.
        Any help would be appreciated and one thing else the power supply does not click
        • tvguy12012012120
          by tvguy12012012120
          02-07-2025, 05:13 PM
        • moosets
          Hisense 55h8f, standby ok, not turning on
          by moosets
          Symptoms: Not turning on after pressing power button on tv. Standby red light on power button turns on when plugged in. Pressing power button on tv causes standby led to turn off for 2 seconds, and then back on red until power is removed (no longer responsive).
          Tried: Removing power, holding power button, returning power. No change.
          Power supply: 244194 RSAG7.820.8805/ROH
          Main board: 244187B, RSAG7.820.8833/ROH
          Opened back and inspected all boards, no obvious damage anywhere.
          The power supply is making a slight clicking noise, maybe a...
          12-08-2021, 11:55 AM
        • stylishconsultant
          un60j620dafxza - Samsung No Display Problem
          by stylishconsultant
          Hi All,
          Need help.
          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
          09-04-2024, 03:26 AM
        • fharris1977
          Vizio D50u-D1 Dead Set No Standby
          by fharris1977
          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
          12-28-2023, 10:25 AM
