Vizio E470i-A0 Question
  • ny_jets_head
    • Apr 2014
    • 70
    • usa
    Is there anyway to check the LED array without disassembling it.
    I have aprox 130 v on the v outs when they are not on. I assume this is because the connection is open to the PS
    It works sometimes for a while and then it quits.
    Has anyone found a connection issue inside causing this?
    Thanks!
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Vizio E470i-A0 Question
    When it works for a while what are the voltages on the connectors? They may also be printed on the power supply.
    • ny_jets_head
      • Apr 2014
      • 70
      • usa
      I'll try to get that if I can get it to stay on long enough.
      What should I expect
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        There should be a legend on the power supply board giving the various voltages on it at the various connectors.
        Some photo's could help.
        • ny_jets_head
          • Apr 2014
          • 70
          • usa
          I got lucky today and found a junk LG unit that has the same panel (almost.)
          I connected the panel to the Vizio and the backlight works proving the problem is with the LED array.
          The back plate is not the same, IE mounting points, so I plan on using the LG's backlight parts in the Vizios panel
          There are no voltages marked on the PS board for the backlights.
          I will post the working voltages when I get the panel fixed.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            In post #1 "it works sometimes" then I wonder if you have a problem with the led strip connectors under the panel and not the leds themselves which is a problem found quite often. Soldering wire links across the connectors resolves this problem.
            • ny_jets_head
              • Apr 2014
              • 70
              • usa
              I guess we will see.. I have to disassemble the panel in any case so I might as well put in a working parts.
              I will check out the old connector and see if it's bad.. I assume it's possibly open.
              • ny_jets_head
                • Apr 2014
                • 70
                • usa
                Originally posted by dick_barton
                In post #1 "it works sometimes" then I wonder if you have a problem with the led strip connectors under the panel and not the LED themselves which is a problem found quite often. Soldering wire links across the connectors resolves this problem.
                Not the issue. The connector PCB was fine.
                The bottom row left side was causing the the problem with shutdown.
                After I replaced that strip it fired up and I still had an issue.
                I tested the suspect Left strips with a 20V power supply, the bottom left was completely dead. You can test the Left sides with a 20V supply but it's not enough to fire the whole strip. My guess is you can get the entire strip to fire if you have a supply that can bring 40 or 50 VDC to the entire strip.
                The right side would not test this way.
                The middle three rows were not firing.
                Solution: Replace the left side L1 strip on the second from the top. The middle rows fired but still issues.
                Three LEDs were out on different strips. Second row R1 right most, 4 row R1 right most, fifth row L1 has an LED that is slow starting takes about 10 seconds to fire.
                Voltages while running: Will post when I get it off its back and reassembled.
                The donor LG set had a lot of bad parts not enough to complete the job unfortunately
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • mrtek
                  Vizio M65-C1
                  by mrtek
                  Hi.
                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                  07-14-2025, 07:28 PM
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • csmith
                  Vizio D50u-D1 Powers up no picture
                  by csmith
                  I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                  Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                  supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                  issue. Set will power up with remote but not power off....
                  07-11-2025, 11:52 AM
