hi guys looking for some help. i have a panasonic tx-l42et60b with vertical white, grey lines, the lines are not solid and seem evenly spaced right across the screen. do not get them when menu is brought up, but get them on self test screen. i have tried a different tcon board , could it be the main board ?. any help would be grateful
panasonic tx-l42et60b vertical lines
Re: panasonic tx-l42et60b vertical lines
Look like Mb to me, if I recall Bga solder failures on the mainboards is common on this set.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by pniHi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
by FalkiHello there, ive recently found an older 55inch Samsung SmartTV.
A similar issue has been posted as well but also with no actual response ...6 Photos -
First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
tried blocking LC lines too, but same results
is it lcd panel issue or tcon board issue?... -
by gpo23Hello,
i order a t-con because i had bad colors on my SONY KDL-40V3000 :
With the new t-con the color are good but there are vertical lines on all the screen :
I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
Is there a way to fix the vertical lines on the new t-con ?
Thank you for your help
gpo23... - Loading...
