LG 42LW4500-LB Need help with repair of PSU
    replied
    Re: LG 42LW4500-LB Need help with repair of PSU
    Originally posted by UndeadLuke
    the red marked one
    That is MOV and it is NOT BAD, if it is activated the main fuse would have blown, it is for surge protection and it is not needed for the TV to function.
    You should be able to read 230VAC between the two legs of that MOV because it is basically connected in parallel with that grey line filter cap which are connected between Line and Neutral.
    You are looking at the wrong section.
    There is NOTHING WRONG with that MOV!
    http://www.mouser.com/ProductDetail/...IfAz8bpg%3D%3D
    replied
    I do not understand which part is bad TH501, TH101?
  • UndeadLuke
    replied
    the red marked one
  • UndeadLuke
    replied
    Originally posted by budm
    That is MOV VA101 and it does not look like it is damaged, if it has been activated it would have blown the main AC fuse.
    NTC TH501 is for the inrush current limiter for the STANDBY power supply section.
    NTC TH101 is for the inrush current limiter for the MAIN power supply section.
    All fuses are Okey main AC fuse is before this little b*tch I want to know what is it and what i can replace it iam agry of it as I sed I had no voltage after the part I will mark it on anotherpost I cant get no voltage on the relay so relay cant switch the voltage to diodes when you press power button it will imidietly turn off TV so i cant turn it on i think the marked part is definetly bad please tell me what it is and what can i replace with it :/
  • UndeadLuke
    replied
    Originally posted by syaoran123
    How do you know the power supply is faulty? I would test the fuses first to see if theyre ok.
    Its faulty .. I checked all fuses and they are OK .. all of them
  • syaoran123
    replied
    replied
    The black thing right to geay capacitor on main is what because it got damaged and no fuse after this part
    replied
    OK, so far you do have standby Voltage otherwise based on Post #1 "Hi guys today my TV stops working (it woudnt turn on only led shine so the power goes into it)"
    Looking the board layout, you will not have any DCV between the two legs on any of the filter caps C612~C614 until you have > 2VDC at the 'PWR-ON' pin of the connector P201 to turn on the power relay RL101 to supply the 230VAC to the bridge rectifier BD101.
    So check and see if you have DCV at 'PWR-ON' pin or not when the power switch is activated.
  • UndeadLuke
    replied
  • UndeadLuke
    replied
    Are these P/N printed on your board?
    Is this the EXACT matched of your board?
    LG EAY62169801 (EAX62865401/8)
    Pictures provided by shopjimmy.
    Yes
  • UndeadLuke
    replied
    Yes
    replied
    replied
    BTW, I cannot read the PCBA P/N as printed on the barcode sticker to look for more info about the board.
    replied
    We need clear straight shot pictures of the whole board.
    There is a bridge rectifier (4-pin black device) mounted on the heatsink, you need to check the ACV between the two inner legs, it should have 230VAC between those two legs.
    https://www.badcaps.net/forum/attach...8&d=1479570017
  • UndeadLuke
    replied
    https://www.badcaps.net/forum/attach...7&d=1479570017
    So the fuse to left of the line filter cap (grey cap) is good for sure?
    Are you getting 230VAC between the two legs of that grey cap?
    Yes 250VAC on gray cap on right side of it its some type of varistor or part (i dont know what it is and which one i need to replace) this part has voltage on + but if you try + and - no voltage everything after that it has no or bad voltage in miliamperes
    replied
  • UndeadLuke
    replied
    Okey guys So I make big progresws today I check the big capacitors and no voltage on them the voltage stops on part INR or LNR next to main gray CAP so this part is definitly damaged does anyone know which one i need to replace ? it looks like Varistor but i dont know nothing about it
  • dick_barton
    replied
    To start off, what is the DC voltage across those capacitors. See post #11
  • UndeadLuke
    replied
    I will wait 2 days and try to find the problem with my teacher of electrotechnics
  • UndeadLuke
    replied
    Originally posted by dick_barton
    The incoming mains of 230v ac is rectified to produce DC and then that DC voltage is increased by the circuit to approximately 380 - 400V DC.
    There is no point in changing anything until you find that it is faulty!!!
    Ah okey thanks I wil try check it with my teacher but also i found something this board has 2 circuit primary and secondary and i cant measure ohms on resistors on second circuit thats weird on first sector of board theres no problem with measure ohms on resistor
  • dj8452000
    How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
    by dj8452000
    I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
    02-18-2025, 08:28 AM
  • nmbb
    Can not find Model/Value of Thermistor.
    by nmbb
    Machine: Autoclave.
    Brand/Model: SANYO MLS-3780
    Manual: (Sorry search option not working on this PDF)
    Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
    06-02-2022, 05:55 PM
  • Use2bavolvo
    Magic chef oven - thermistor ref voltage issue
    by Use2bavolvo
    I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
    Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
    01-19-2023, 01:32 AM
  • trex66
    Craftsman 82345 Multimeter broke!
    by trex66
    My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
    03-04-2025, 04:26 PM
  • Ymotaqi
    ROG STRIX Z590-A GAMING WIFI has no POST no BEEP no diag LED
    by Ymotaqi
    The motherboard does not POST and has the following symptoms:
    When the power button is pressed, the fans and RGB turns on.
    When the power button is pressed, the motherboard voltages 12, 5, and 3 are connected.
    The motherboard does not beep.
    None of the diagnostic LEDs light up.
    USB voltage is off.
    VCORE voltage is off.
    The BIOS software was downloaded from Asus site and installed using the Q FLASH button, but it made no difference.
    I would appreciate it if anyone could guide me on the cause of the problem.
    01-12-2025, 04:15 AM
