md301b MAGNAVOX LCD controls dont work no remote
  • Packard93
    • Jul 2016
    • 81
    I bought tv that has buttons dont work .But when Im able to get hdmi input selected it will work . But I cant use the buttons after a few seconds to a min they stop. They way I get it to switch is using any my old main but it get locked too into dvd mode . When I get it to switch with old board I switch back to new board and I select my hdmi 1 input for my time warner box I get a great pic and sound but after 1 min the controls for sound and menu power any button on tv is inoperable. . Ive been trying to diagnosis tv . md301b MAGNAVOX LCD controls dont work switch boards works temporary tv has a dvd player that spins but dont show pic when I locks into the dvd switching boards is the only way to get back to hdmi and then i can get volume buttons work temporily after i have output I leve it at that. But buttons on tv dont work after a min of tv . The tv has a dvd /combo that it get stuck in and I cant switch unless i switch my mainboards. then I switch on either board temporarily. Dvd causes issie Im thinking but I dont know where should I test with multimeter?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: md301b MAGNAVOX LCD controls dont work no remote
    leaky tact switches.
    do you smoke?
    replace all the switches on the button assy.
    • Packard93
      • Jul 2016
      • 81
      after further diagnostic I took my multimeter checking to see if voltages would change when button was depressed . I seen decreases in voltage meaning buttons were functioning. So I decided to screw with the dvd player some more dvd spit out and I noticed for split second again the buttons worked as I was power up. So I remember reading the service manual . It said you should be able to get a manaul eject. so i pushed the mechanism and got it to fully extend as it should . Now all buttons work and I switch inputs menu sound up/down all ok everything power button ok menu ok . I checked to see if problem would come back it has not tv performing perfectly . This happened with dvd fully extends out the disc tray. Im think it changes the output voltage to the board when it extends out. And it was waiting for the voltage . Its like the computer in my car they set code in a car though like output voltage does on tv but no code. INPUT AND output voltages have to be set a certain way. That tray extended made tv buttons work flawlessly.
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • Natob82
        Micro Momentary Push Switch?
        by Natob82
        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
        12-21-2022, 05:22 AM
      • grimacelord
        NEC TurboExpress On/Off Power Switch Replacement Help
        by grimacelord
        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
        11-09-2023, 09:49 AM
      • SluggerB
        Help making a switch work the opposite way with a relay
        by SluggerB
        I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
        I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
        It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
        02-07-2025, 07:57 PM
      • Dannyx
        "Kinetic" 433Mhz transmitter/receiver discussion
        by Dannyx
        Good day folks.
        TL;DR: has anyone tried pairing one of THESE "kinetic" battery-less switches with THESE generic remote modules ?
        Details: I recently got hit by this craze of wanting to add remote controls to the lights around my house, so I went with those generic 433Mhz remote relay modules found everywhere, which are really basic, easy to use and work well, since I used them before in other projects. What I like most about them is they accept all kinds of 433Mhz remotes that float around Aliexpress, since they're all the same under the hood, save for the...
        03-08-2022, 11:01 AM
