Sony KV25FS150 no startup.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    I am presently servicing a Sony KV25FS150 which does not power on when the
    power switch is pressed.The standby light is not lighted when the tv is plugged
    to the AC supply or blinking.I know when problems arise in Sony televisions the
    standby light blinks.There is DC on the filter capacitor,the regulator and also the flyback transformer.
  • R_J
    • Jun 2012
    • 9546
    Re: Sony KV25FS150 no startup.
    Do you have the schematic? kv29FS150 should be the same.
    Do you have 135 volts on the horzontal output transistor (Q511)
    Flyback tranformer is the high voltage transformer (T503)
    or do you mean the power transformer (T602)
    The SWITCHING regulator ic in the power supply is STR-W6753 It should have 150 volts on pin (1) and 11 volts on pin (4) [measured to HOT ground]
    Check the resistance of R610 & R619 .33 & .22 ohm
    • SEAWOLF
      • Nov 2011
      • 177
      I have a schematic and I have 43.3 volts on the horizontal output transistor and
      162 volts on pin(1) and 10.4 volts on pin (4) for STR-W6735.These voltages are
      taken when the television is in standby,because it will not switch on when the
      power switch is pressed.The standby LED is not lighted when the television is in
      standby.
      • R_J
        • Jun 2012
        • 9546
        Check D517 and D518 I replaced lots of those diodes in the past, usually one shorts, they are near the horz. putput transistor, you should have 143v on that transistor and about 70v on the driver Q506
        • rabbituk
          Sony HCD BX7700dbi CMT flashing standby
          by rabbituk
          I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
          So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
          02-11-2025, 05:05 PM
        • androripara
          Sony Bravia 55HX820 - 4 times blinking red standby led
          by androripara
          i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
          I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
          Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
          10-19-2023, 05:16 AM
        • Mcfeetroy
          Fishing bite alarm drains battery
          by Mcfeetroy
          Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
          08-01-2025, 03:52 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • denisten
          Sony STR-DB870QS standby transformer
          by denisten
          Hi everyone, i am a newbie here and i hope i will find the help i need. I have the above mentioned receiver with standby transformer's primary coil damaged. I have searched the net without success to find any tech data about this transformer. I have only the Sony part number1-437-313-11 and TAM Malaysia M0126. I guess i could find replacement for it, but i need to know the secondary coil voltages and VA. It is 220v on the primary. It has 5 pins on the secondary, the outer two are not used and i have 6.5 ohms between pins 2and 4, 3,9 ohms between 2 and 3, and 3,6 ohms between 3 and 4. Can someone...
          04-14-2023, 03:24 AM
