Plasma tv zenith (lg ?) 60pv220 works 10 min and shuts down
  • anibal2100
    Anibal
    • 31
    Hello everybody. This is my first post here and I'd like to thank you in advance for any help I can get to solve this problem.
    This set is almost identical as the LG 60PV400.
    The unit works for about 10 minutes and then shuts down.
    If I turn it on it will work for another 10 (or so) min and again will go off.
    Once or twice just the picture will go off and the sound will stay on so I discarded the mainboard. When that happened I had a chance to check voltages on the PS:
    V 5V = 5.1V (ok)
    V 17V = 17V (audio ok)
    Vs = 202 V (should be 204V)
    Va = 57 V (ok)
    Y-main
    Vsc = 0V
    Z-sus
    Vzb = 0v
    V18V (from Y-main to Z-sus ) = 4.7V
    This last voltage will go normal (18V) once I cycle the TV.
    Could be a logic board problem ?
    Thanks again for any help !
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: Plasma tv zenith (lg ?) 60pv220 works 10 min and shuts down
    Sounds like cracked solder joint either on the power supply or on one of the sustain boards. You should be able to fix this by checking all transistors/diodes screwed into the heat sinks of the power supply along with any components in close proximity to the pads used by those transistors/diodes. Check the transformer as well those can get hot.
    • anibal2100
      Anibal
      • 31
      Thanks Nick !. I'll start reviewing all joins first hour tomorrow and will post the results.
      • Hamie
        • Apr 2014
        • 1383
        If this TV uses the z-sus EBR67820001
        Then you need to inspect the solder joints on the coils.
        Stop using, or even testing the tv untill you've inspected these - if they completely break free from their pads it will lead to an expensive and difficult repair.
        • anibal2100
          Anibal
          • 31
          I already checked all (one by one) solders and they look perfect (under stereoscope). The problem remains the same, I'm thinking the logic board could be the issue
          By the way, yes Hamie, it has z-sus EBR67820001 but fortunately solders are all good. You are right I have another TV (LG 60pv400) with the problem you described and is a nightmare, I just resolder the coils, replaced 6 IGBT's and the Y-main (which was working fine) shorted ! I just gave up on it.
          Returning to the Zenith, the weird thing is that it works fine for 10 ~ 30 min
          and a couple of times just the picture went off with sound ok.
          I watched this video and make think about the logic board :
          https://www.youtube.com/watch?v=HNzpnnlkiV4
          What do you think ?
          • Hamie
            • Apr 2014
            • 1383
            It's possible but there could be a whole host of problems that cause no picture.
            Check voltages when the picture goes blank.
            VZB
            -Vy
            Vsc
            See if any drop, if they do then concentrate on that board.
            Run test patterns with mainboard disconnected. See if the fault Remains.
            • anibal2100
              Anibal
              • 31
              Now it has sound and Vsc=0, -Vy=0, Vzb=0, V18v=4.7V (this voltage is generated inside the Y-board and goes from Y-main to Z-sus, straight through logic board)
              • Hamie
                • Apr 2014
                • 1383
                On the PZ950 you can disconnect the z-sus and the tv will run and show an image. See if it brings the picture back.
                • anibal2100
                  Anibal
                  • 31
                  Has been more than an hour and the sound still holds.
                  Now after cycling (on-off) there is only sound, no image.
                  Turn it off, disconnected Z-sus, no image just sound.
                  Still thinking control board (logic) is failing..
                  I'll let cool to see if it comes back and use air heater over the logic board..
                  Do you think is a way to go ?
                  • anibal2100
                    Anibal
                    • 31
                    Thank you guys for your time and help. No luck with heater over ctrl board. I'll order a new control board as a final try. I'll post results.
                    • baglaivlad
                      A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
                      by baglaivlad
                      Hello everybody!
                      Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
                      After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
                      11-20-2024, 08:14 AM
                    • berriferous
                      Samsung PN43E450A1FXZA (Plasma) - Display up for 4 mins, then shuts itself down
                      by berriferous
                      Set was manufactured in 2012. I'm trying to diagnose where the problem is. I am assuming it is over-currenting after heating up? Display looks fine until it decides to shutdown. If I keep turning it on, it will eventually refuse to power up and requires unplugging to get it to respond again.
                      I originally thought there would be some easily detected bad electrolytic capacitors, but I don't see the telltale signs. There might be some very minimal bulging on one of the x buffer board. BN96-22092A (LJ92-01852A).
                      If I unplug the power feed to the X/Y board (LJ92-01854B), the...
                      12-16-2024, 09:58 AM
                    • pete g
                      zenith plasma tv. the model is Z50PX2D.pix problem
                      by pete g
                      hi, i have a zenith plasma tv. the model is Z50PX2D. i really love this tv. as of late its coming on with 6 vertical lines of white dots. they flicker, the audio seems to affected also with static sounds. all other aspects of the pic are good. i have good color, and no other problems with picture. can someone help? thanks.
                      06-18-2022, 12:10 PM
                    • ZixuTech
                      Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
                      by ZixuTech
                      Hi Guys, a weird case here.
                      This laptop came with damaged hinges, but no liquid signs.
                      It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
                      I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
                      I have replaced bq24780S battery charging chip, no difference.
                      With a connected new battery,...
                      04-03-2022, 04:03 AM
                    • CapLeaker
                      Dell ATX PSU won’t start, but forcing it works fine?
                      by CapLeaker
                      Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                      Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                      10-28-2024, 06:59 PM
