Samsung UE40D5520 KEEPS REBOOTING
  • cvel
    • May 2015
    • 64
    Hi can someone help with a problem I'm having with this TV it was working fine when I bought it from a friend who never had it connected to the Internet. I got it home worked fine until I attempted to connect it via wifi now when switched on it comes up with Samsung logo then turns off turns back on and does the same repeatedly until I unplug it. This is frustrating me. TV is only 2 years old my friend said. Any advice is much appreciated. Thank you
    • 31288
    Re: Samsung UE40D5520 KEEPS REBOOTING
    maybe it tried to do an online update.
    go to samsung website and see if there is an upgrade file for a usb stick.
    • diif
      • Feb 2014
      • 6978
      • England
      Double check this is the correct model number but this page has the firmware. http://www.samsung.com/uk/support/model/UE40D5520RKXXU
      Use a USB memory stick and follow the instructions and try updating the firmware that way.
      • cvel
        • May 2015
        • 64
        Thanks for the reply. I have contacted Samsung on the phone who have said because the TV is 2 years old I will have to take it to a Samsung tech. GAVE me contact details and the tech said it'll be £160 + vat for a main board. Not something I'm willing to accept over the phone without him even looking at it. Although after some research I unplugged the main board and tried the TV again this time it stayed on screen lights nothing else without turning straight off tried again with main board reconnected and shuts itself down and restarts again and again. stuck with what to do now. Don't want to give up on it just yet
        • cvel
          • May 2015
          • 64
          Thanks diif but that model number is just a little different. Would that make any difference or should I try anyway
          • diif
            • Feb 2014
            • 6978
            • England
            Give it a try anyway.
            Format the USB stick to Fat32, download the firmware to it. Double click whilst it's still plugged in to your PC and it should extract a folder to the stick. It's now ready for the TV.
            I can't see the instructions for installing for this model TV but the Samsung I updated about a couple of hours ago needed the TV to be in standby then "Source" on the TV and "Power" on the remote were pressed at the same time. The TV then powered on and did the update.
            • cvel
              • May 2015
              • 64
              I've downloaded it. but cannot get the TV to stay in standby mode just keeps trying to boot. As soon as the wife gets back with the stick I'll try anyway and keep you updated
              • diif
                • Feb 2014
                • 6978
                • England
                Maybe unplug the TV from the wall, plug in the USB then plug in the TV.
                • cvel
                  • May 2015
                  • 64
                  Hi mate. I've tried all of this and still nothing working. IT did look like it was trying to do something then green squares appeared on the screen but turned off and carried on rebooting again.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    What mainboard number is used in this set
                    • cvel
                      • May 2015
                      • 64
                      Number Sorry on the board are UE40D [5520] main- 1018.1 sub 1003
                      SK10BN9405225CD2U4BAH0382
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        nothing shows on google regarding those numbers can you post a clear picture of the mainboard thanks.
                        • cvel
                          • May 2015
                          • 64
                          I can't resize my pic sorry. Other number on board is BN4101660B the board comes up on the images
                          • JABEL01
                            • Mar 2018
                            Hi cvel
                            Did you manage to resolve this issue; I think I am having the same problem and wondered if you managed to fix yours? Thanks in advance.
                            • Hamie
                              • Apr 2014
                              • 1383
                              You can sometimes freeze spray ic1302 get the TV to boot in service menu then factory reset it.
                              Follow this up with a firmware upgrade.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                They also suffer with NAND problems. The 48 pin TSOP.
                                • shomi75
                                  • Mar 2011
                                  • 7
                                  • Serbia
                                  Install new nand with firmware
                                  • viktorkane
                                    • Jul 2018
                                    • 32
                                    • albania
                                    must write firmware nand flash or eeprom
                                    see this link
                                    https://www.elektroda.pl/rtvforum/to....html#15801430
                                      09-07-2024, 05:50 AM
                                    • TR103
                                      by TR103
                                      - it keeps rebooting
                                      01-22-2025, 04:12 PM
                                    • plytek
                                      Samsung QE50Q60TA rebooting
                                      by plytek
                                      Hi all.
                                      I'm trying to fix my Samsung QE50Q60TA TV.
                                      IT's rebooting every few seconds.
                                      I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
                                      Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
                                      Can anyone suggest what I can test and do to get it working again please?...
                                      02-08-2025, 06:02 AM
                                    • unimatrix93
                                      SAMSUNG UE55TU7002KXXH rebooting
                                      by unimatrix93
                                      Hello everyone, I'm working on a Samsung TV that constantly rebooting.
                                      MB/PSU unit: BN9654185QE
                                      It loads up to the main menu then as soon as the backlight goes brighter it reboots.
                                      First I suspected the LCD panel, so a disconnected the LCD display from the mainboard but did the same thing.
                                      Then I removed the backlight connector which only delayed the bootloop by a minute maybe, I know it because I test it with the remote, it does gives the menu sounds a bit longer.
                                      Also I have to note, that the MB/PSU combo gives out a very noticible...
                                      04-07-2025, 09:49 AM
                                      09-06-2024, 11:40 PM
