LED Tv Samsung UE46F6400 image reversed
    LED Tv Samsung UE46F6400 image fliped
    - mainboard was fault , i buy another mainboard, but the image is reversed or flipped
    - i try to enter service menu and search for some settings but nothing
    any help ?
    BN41-01958B
    Re: LED Tv Samsung UE46F6400 image reversed
    reload firmware
      how ? and what firmware ?
        was the mainboard a exact match (all the numbers on pcb and any stickers etc) if not matched to the panel used in your tv it may cause this problem your having
          the mainboard is the same code, but not the same with the label .
          but how i can repair this ?
            look on samsung site see if thay have any firmware for your tv theres usually a guide explaining how to update the firmware etc
            http://www.samsung.com/uk/support/model/UE46F6400AKXXU
            https://cdn.badcaps-static.com/pdfs/...c9862e92f9.pdf
            please remember though you do this at your own risk as i may solve the issue or could make it worse
              firmware http://www.samsung.com/uk/support/model/UE46F6400AKXXU
              as previous poster
                The image can be flipped by changing the screen type in the service menu until you find one that works. I just went through this not long ago with a UN60ES7100. I ended up using a board out of a much cheaper UN40EH5300. It took me about 20-30 tries in the service menu with different screen types but I finally got one that was made for use with the LCD panel reversed. The UN60ES7100 had the t-con at the bottom whereas the UN40EH5300 had it at the top.
                  i try in service menu , but for 46" have only 2 option for panel
                    I switch with a 32" panel and now it`s working, topic can be close
                      Thanks for the update glad it was a easy fix and nice too know you can use diffrent mainboards from diffrent lcd sizes on these sets.
                        My experience was the same. Every setting displayed a clear and correct image but most of them were upside down. I believe the setting I ended up using on the 60" TV was listed for a 50" on my particular board.
                          any help ?
                          BN41-01958B
                          Hello, i saw that you had an identical problem as i have.
                          I have a LED Tv Samsung UE46F6400AWXXH ver 3. The mainboard nr. BN94-06717B.
                          I found a guy who had a UE46F6400 tv but don`t know the product version just the mainboard nr. BN94-06724D. It is possible to change this guys mainboard with mine and will it work?
                          Thanks in advance.
                            To anyone else that finds this thread.
                            On a UE46F6700 .. The type options are as below:
                            The ones marked x didn't fix the issue for me
                            The ones marked v did.
                            Everything else I didn't try
                            screen modes
                            NONE
                            22A6TF1E
                            32A6AH0S
                            32R6AH0S
                            32P6AH0S
                            32B6AH0S
                            32R6AF0S
                            32P6AF0S
                            32A1AF0s
                            32A6AF0S
                            32A1AF6S
                            40A1AF0S
                            40A6AF0S
                            40A1AF6V
                            x 46A1AF0S
                            x 46A6AF0S
                            x 46A1AF6V
                            x 46A2UF7E
                            55A1AF0S
                            55A1AF6V
                            55A2UF7E
                            60A2UF7E
                            60H1AF0S
                            60H1AF6S
                            60H2UF7E
                            65L1AF0S
                            65L2UF7E
                            65D1AF0S
                            32R1AF0S
                            v 46R1AF0S (HDMI, RES: 1080P)
                            v 46R1AF6V (HDMI, RES: 1080P)
                            50R6AF0S
                            50R1AF0S
                            50R1AF6V
                            50RF7E
                            55R1AF6V
                            32P1AF0S
                            50P1AF0S
                            50P1AF6V
                            55P1AF0S
                            55P1AF6V
                            51FFHc
                            60FFHc
                            60FSCr
                            64FFHc
                            22B6TF0E
                            22L6TF0E
                            32S6AH0S
                            36P6AF0S
                            36L6AF0S
                            40H6AF0S
                            42R6AF0S
                            46R6AF0S
                            50P6AF0S
                            28S6AH0S
                            72A1UF6V
                            46A2UF8E
                            55A2UF8E
                            62L2UF8E
                            55R1AF0S
                            62A2UF7E
                            32A1AF1S
                            40A1AF1S
                            46A1AF1S
                            55A1AF1S
                            40A1AFAV
                            46A1AFAV
                            55A1AFAV
                            65A2UF8E
                            32H6AF0S
                            55A1AF2S
                            60H1AF1S
                            60H1AFAS
                            65L1AF1S
                            46A2UFEE
                            55A2UFEE
                            60A2UFEE
                            55A1AF3S
                            72A1UFAV
                            40A1AF0D
                            46A1AF0D
                            50P1AF1S
                            50P1AFAV
                            40A6AF1D
                            46A6AF1D
                            50R6AF1D
