Samsung 50" Plasma relay clicks, nothing else
  • Snype32
    • Jun 2011
    • 76
    I have a Samsung pn50c540g3f 50" plasma. When plugged in, the red power light comes on. when touched, the tv clicks a few times, and goes back to the red light. Screen does not come on. I looked around on the net a bit and it looks like it could be bad caps, or the buffer board. Just wondering if anybody here is familiar with this, and where I should start. Thanks!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung 50" Plasma relay clicks, nothing else
    Good god, how we supposed to guess ? Take the back off and get diagnosing it lol ? No point just throwing random ideas in there you need to find out what you need to add to a thread and what to test which there are plenty of things on here to help.
    • Snype32
      • Jun 2011
      • 76
      Sorry I should have clarified, I have taken the back off, all caps appear fine. It seems like from what I have found, there are usually two culprits, bad buffer boards, and power supply/bad caps. I was mostly wondering if people here were familiar enough with these to say which was more likely. If bad buffers are a strong possibility, I thought I would save everybody some time because I don't have the facilities to fix that. Bad caps are no problem for me to fix. I'll be doing some VA and VS checks shortly.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        On this chassis check for shorts from Vs to ground on the Ysus and Xsus the buffers are normally very reliable in this chassis sus boards are not and usually short causing Psu to current limit and click over and over.
        • Snype32
          • Jun 2011
          • 76
          Ok...so I've done a few tests. First to clarify, when first powered on, there are 2 back to back clicks, short pause then the third click. It will repeat that every time the power button is clicked. It happens fairly quick, so hard to get an accurate reading. Next I disconnected the cable going from the main power supply to the second board in my pics. Is that the Xsys or Ysus board? anyway, with that disconnected, I tested VA and VS on the main power supply. They momentarily read their specified voltages and then drop off. The tv also sings its little samsung song. I tested for shorts on what I assume is either the Ysus or Xsus, and sure enough, there is very little resistance from ground to VS. Not quite a dead short, but very close. So I'm guessing some component is shorted on that board.
          Thanks for the help so far.
          • Snype32
            • Jun 2011
            • 76
            Looked up the board, it's the ysus
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Ok sounds like the Ysus then, could possibly be that the Xsus is damaged too when the Ysus blew as these use chained ERC (energy recovery) meaning if the Y blows it can kill the X basically. Does your meter have diode mode easier to test ?
              • Snype32
                • Jun 2011
                • 76
                Yes I have a meter with that function. What area should I start testing? There looks to be a couple rows of what look like mosfets. I was thinking of starting there unless there is a more likely place to go.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Start testing the devices mounted on a heatsink but mainly if Vs is shorted to ground to diagnose the bad susboard.
                  • Snype32
                    • Jun 2011
                    • 76
                    So I think I found the culprit. a RJP30E2 transistor. Shorted in every direction. I was told that this would be a replacement:
                    https://www.digikey.com/product-sear...DPK-00%23T0-ND
                    Higher wattage, voltage, and current rating. I also found a small burnt trace and an assuming that it happened because of the shorted part. Should I check anything else out or hope that this is it?
                    • Snype32
                      • Jun 2011
                      • 76
                      I just removed and tested a rd2006 rectifier as well. It appears to be shorted as well? how are these tested?
                      Thanks!
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Same as a transistor, you should have a voltage drop in one direction and not in the other. Also the diodes rarely rarely fail on sustain electronics. There might be other transistors shorted so keep checking the circuit before removing the diode.
                        • Snype32
                          • Jun 2011
                          • 76
                          The RD2006 is defiantly shorted in both directions. I will be double checking the other components as well.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Ok best to check everything let me know
                              09-07-2024, 05:50 AM
                              Samsung LN46b530p7f – relay clicks and backlight cycling, sound OK
                              by momaka
                              I got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
                              Problem:
                              Backlight cycles On and Off.
                              Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark....
                              01-17-2019, 11:23 PM
                            • Journey11
                              Samsung TV won't turn on ... keeps cycling the power relay on & off
                              by Journey11
                              Hi All,
                              First time posting here ... my name is Kevin but my friends call me Journey.
                              I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                              After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                              It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                              07-04-2024, 02:44 PM
                              09-06-2024, 11:40 PM
