Sony KDL-52W5150 Bravia
  • ben74820
    • Oct 2016
    • 12
    My unit has started this problem since a power surge (lightning). Here is the problem when I first turn on the unit I get Horzi. lines of different sizes and color all the way across with the picture in the background faintly, also seems to have some retention in pic. Now the odd thing you can turn the unit off and on a few times in say 5 mins. and it works just fine from then on no matter how long you let it stay on. Has a great pix. Sites I have searched seem to say this is a bad panel this is so hard to believe because it doesn't stay this way all the time. I am on Direct TV with HDMI inputs. Does anyone think a power supply might cause this problem? Maybe a bad cap and when it warms up it will work.
    Thanks for ur input to my problem.
    Ben
  • R_J
    • 9624
    Re: Sony KDL-52W5150 Bravia
    Usually this points to a power supply problem, as long at the tv was pluged in the power supply works, but when power is removed for a while and restored thats when the problem can show up.
    usually weak capactors, and when the power is restored and the caps heat up a bit they start to work, the longer the tv is on the better they get so the fault seems to go away. post some pictures of the boards and of the screen when its acting up and maybe someone can help
      We need good clear pictures of the whole backside of the TV so we can see how all the boards are connected together, then good clear pictures of the power supply board.
      What you can also do is to unplug the TV from the outlet then use hair dryer to heat the power supply board for 2~3 minutes then plug the TV in and turn it on to see if the TV will startup properly, you should also make sure all the circuit board mountings screws are on tight.
      • romich57
        • Dec 2016
        I am having a similar problem, the picture below is a good representation of the issue, then after a few power cycles, I am back to perfect picture.
        Is this a T Con issue?
        Panel Issue? - seems odd since it does show fine after some power recycles
        Power Issue?
        • JUCaESAl
          Sony bravia KD-65AF9
          by JUCaESAl
          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
          10-20-2025, 04:03 AM
        • alegatorul
          sony bravia kdl-43w756c, no power, no sound
          by alegatorul
          the charger brick has 19,2-19,3 vcc
          changed the inverter board same result.
          where should i start?
          cheers
          11-15-2025, 10:00 AM
        • justin35
          Sony bravia kdl-43w755c - boot loop
          by justin35
          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
          from what i read online it looks to be an emmc issue…
          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
          i took out the board and say an samsung 16gb emmc
          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
          i could try to put one instead of the 16gb one, but will it work?
          where do i get the software from?
          any help will be much appreciated!...
          03-06-2024, 12:26 PM
          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
          10-16-2024, 05:15 AM
        • Spc.
          Sony Bravia KD43XF7596BAEP - Android no picture
          by Spc.
          Greetings everyone.
          I also have Sony Bravia, model:
          Sony Bravia KD43XF7596BAEP - Android.
          What happend is that image dissapeared while we were watching tv.
          Diagnostics:
          1. TV turns on, no errors
          2. Backlight turs on, no errors
          3. Power indicator turns on, white color, no errors
          4. Menu works on android, you can hear sound while switching channels
          5. Volume up and down works via TV remote and via buttons
          6. Tunner works, HEVC / MPEG-4 decoder works
          7. I get audio from channels
          8. No picture is present,...
          05-19-2022, 04:28 AM
