Toshiba 50L2300U flickering horizontal lines, black (dimmed) screen
  • SdlewisSr
    • Oct 2015
    • 146
    About 4 months ago I went to a friend's house to look at their TV. It was a Toshiba LED model 50L2300U. It had flickering horizontal lines in the bottom quarter of the screen (see attached photos). At the time she did not want to pay to have it repaired so she continued to use it until this week when the screen went black. She purchased another TV and gave me the Toshiba for parts or to fix it if I could.
    When I got the TV home, the screen worked (with horizontal lines as mentioned above) for a few seconds to a few minutes after turning on the TV. After removing the back cover and checking the voltages, I discovered that the main board was just dimming the screen. The voltage on the PWM pin was only 1v. I jumpered the BL ON/OFF to the PWM so that I could keep the screen on to take pictures and allow the channels to program. She only used a cable box via HDMI. I found the lines are present when using the tuner in addition to HDMI. Here is a link to a short video of the lines (https://youtu.be/kW7xyUYVffk). I am assuming that whatever is causing the horizontal lines is causing the main board to dim the screen.
    After searching online, I found many others having problems with these lines on Toshiba LED TV's, but no solutions. Has anyone experienced this before and resolved it?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Toshiba 50L2300U flickering horizontal lines, black (dimmed) screen
    Failing panel not fixable sorry
    • SdlewisSr
      • Oct 2015
      • 146
      Big Bummer
      This TV has a Sep 2013 manufacturer date. When I was checking the Toshiba forums, I found this same problem and they were only a couple years old also.
      Thanks for your help
      • SdlewisSr
        • Oct 2015
        • 146
        ReeceyBurger123 the lines are not random. They cycle on for about 2 seconds and cycle off for the same amount of time. See video (https://youtu.be/G7WzX4tTLA0). Is there any chance that this is being caused by the T-Conn or by something other than the panel?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Its the panel nothing else, the driver is shorting and causing distortions. I actually sold a 50" Toshiba 6 months ago with Lg panel failed in the same way with horizontal lines just this week.
          • SdlewisSr
            • Oct 2015
            • 146
            OK. Thanks for your assistance. Have a blessed day
            • SdlewisSr
              • Oct 2015
              • 146
              Just a final note. I decided to check the backlight LED's. I replaced 10 bad LED's and the backlights now work normally. Still have the horizontal lines.
              • budwich
                • Jul 2015
                • 3097
                not sure of the panel design, but in sharp / visio / sony, if there are tabs on the sides of the panel (each side), then you might be able to "save" the panel by removing the side that is bad. On mentioned panels, this "operation" allows the set to still function and look normal.
                • SdlewisSr
                  • Oct 2015
                  • 146
                  Hi budwich,
                  this has tabs only on the bottom.
                  • budwich
                    • Jul 2015
                    • 3097
                    :-( OK.... but there is also the "tape cutoff / mask" method. On sets where the bottom tabs are also responsible for driving the sides, people have found the placing a small piece of tape to mask off a bit of the pins on the connector (of interest) at the tcon to panel connector provides a similar "save". You might try that... you have to experiment a bit to find the right position and pins to mask. There are various threads about this and the success. The method isn't as "drastic" as the "side tab removal" so there is nothing lost in the experiment. It would be a shame that you spent the time to replaced leds and can't get a good display out of the panel.
                    • SdlewisSr
                      • Oct 2015
                      • 146
                      Thanks budwich!
                      I will look into this method.
                      • budwich
                        • Jul 2015
                        • 3097
                        just one more point... I don't think you can see "side tabs" from the back of the set. You need to remove the bezel and look at the front side..... just in case you are making the statement about "no side tabs" based on your posted pictures or you know for a fact.
                        • SdlewisSr
                          • Oct 2015
                          • 146
                          I had the panel apart repairing the LED's and know that the tabs are on the bottom only. I will look into the "tape cutoff / mask" method.
                          • SdlewisSr
                            • Oct 2015
                            • 146
                            I finally got around to trying the taping/masking off method. I watched this "Do It With Dave" YouTube video (https://www.youtube.com/watch?v=j7vl7-vZEL8) which pointed me in the right direction. I masked off a portion of the right edge of the left ribbon cable leaving the T-Con board (see attached photos). It was trial and error finding the exact size of tape to use and where to use it. In photo (IMG_4334.JPG) you can see a black dot on the cable which marks the inner edge of the piece of tape that I used. In photo (IMG_4339.JPG) you can see the tape shining where it covers the connections. You can see the working TV picture at (https://youtu.be/FAHFmqIeDTg).
                            Thanks to everyone who posted with helpful suggestions!!!!
                            Have a blessed day!!!!
                            • budwich
                              • Jul 2015
                              • 3097
                              glad it worked out
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
                              • oxi1158
                                Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
                                by oxi1158
                                My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
                                I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
                                10-09-2020, 08:37 PM
                              • Ihandyrepair
                                Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                by Ihandyrepair
                                Hi guys
                                I just started fixing 4k TV few months ago. so I am still learning a lot
                                I got this tv from friend complaint is ghosting or horizontal lines on image.
                                never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                then it started to show the ghosting white image.
                                I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                it has 3 thin small boards at the bottom of the...
                                12-05-2022, 04:18 PM
                                09-06-2024, 05:27 AM
                              • ggil44
                                Sony XBR-65X750D Horizontal lines bottom of screen
                                by ggil44
                                Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                05-30-2023, 07:51 PM
