Need help with Toshiba 32AV502R TV. No picture or sound, just lines
  • shaundh
    • Aug 2016
    • 17
    I'm having a hard time getting started trouble shooting this TV. When I got it, it would turn on (I get green light and backlight) but I got no picture or any sound. I just got some vertical greenish lines on the left side of the screen. I took the panel apart and touched the flex cables connected and there was no change. I switched inputs and no change or sound. So I guessed it was the main board. So I found a mainboard on ebay, installed it, and the exact same behavior as before. I was sure it was the main board because I got NO respose from volume, input, menu, nothing. But it's still doing the same thing. I have a meter and I'm going to test the voltages now, but I'm pretty stumped. Any advise on where to start?
  • shaundh
    • Aug 2016
    • 17
    Re: Need help with Toshiba 32AV502R TV. No picture or sound, just lines
    This is what it looks like.
    Update: I finally got sound from the TV. I kept switching through the inputs and turning up the volume until I got a noise from the Apple TV menu. I can hear clearly but there is no movement on the screen. There are greenish white vertical lines across the whole screen now. I'm guessing that the panel is bad. It's just strange that I can't seem to agitate the problem by touching the flex cables. So, am I right in assuming the panel is bad?
    • shaundh
      • Aug 2016
      • 17
      Here is what it looks like with programming playing.
        Bad panel.
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • jord4231
          Toshiba 37AV500A Regza TV good power supply no sound no picture
          by jord4231
          Hi Everyone,
          I'm working on a Toshiba 37AV500A Regza TV.
          The issue:
          TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
          The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
          I checked the PSU voltages and everything looked good.
          No bulging caps or signs of heat.
          24v aud = 24.41v
          12v = 11.98v
          5v = 5.062
          p_o/f = Goes high...
          03-29-2022, 09:21 PM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
