Samsung PS42A456P2D main board fault
  • llonen
    • Sep 2014
    • 495
    • hampshire
    I am fairly certain I have a main board fault with this set, relevant voltages appear within spec and the plasma panel is firing, no lines or artefacts. I am however not getting the chime on startup and or any logo or other text, the set starts up and shuts down with the panel buttons. Before ordering a replacement main board I want to run a panel test, see below a pic of the logic board and what I presume are the panel test pins which ones do I need to connect together and do I need to remove the lvds cable from the main board.
    Many thanks in advance.
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung PS42A456P2D main board fault
    Pins 3 and 4
    And yes disconnect cable
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Them control boards have a flash Ic that drives the information for the panel which has a habit of failing causing panel to prime but no image same as PS42Q96 sets etc. But yes disconnect the Lvds and jumper the pins.
      • llonen
        • Sep 2014
        • 495
        • hampshire
        I have have a very good test pattern displayed, so where does that leave me, I get no chime from the set itself so, but with the jumper disconnected i get no chime and, while the panel primes and stays primed. Control board or main signal board, I am guessing they are not particularly repairable either.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Mainboard failure, replace mainboard or reflow it.
          • llonen
            • Sep 2014
            • 495
            • hampshire
            I have a board here from a Samsung PS50A456P2DXXU which I recently stripped as the screen had a number of stuck lines, identical physical layout I was wondering if it would be compatible, I have the remote for the board as well.
            Model
            number 450_normal_idTV
            Pcb number BN41 00980A
            • llonen
              • Sep 2014
              • 495
              • hampshire
              Was lucky to obtain a replacement main board for this set, very nice picture on this one now.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Good work thanks for the update
                • Asraf Atb
                  by Asraf Atb
                  01-27-2025, 05:02 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • Lee M.
                  Samsung UN75RU8000FXZA bad main board?
                  by Lee M.
                  When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                  11-08-2023, 07:46 PM
                • JDC
                  (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                  by JDC
                  ONN 100012588
                  Issue: No Power, Then Rebooting After Main Board Change
                  Short answer: replace main board and power board
                  Technical answer: replace main board and Q306 & Q307 on power board.
                  Long answer:
                  TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                  07-15-2022, 07:39 AM
