Dropping LED voltage on 17IPS20
+ More Options
Posts
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Continuing from this post, I like to update on my other finding, before I conclude it's a led strip issue.
    Removing where the led wire connects to on the psu, I placed a MM to read the voltage. It reads 50v but keeps going down; down below 30v! Is this normal? What causes the voltage to be dropping.
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Dropping LED voltage on 17IPS20
    Does this TV turn on AT ALL ? What you're describing sounds very much like a failed backlight LED. The power supply has just cut the power going to the LED strips, so those volts you're getting is the caps discharging after they've received some brief power. With the TV off, the red lead going to the LEDs should read around 24v from what I know. When you switch the set on, it should first jump to 100+ volts, then stabilize at around 85v with a functional backlight. A faulty backlight will still shoot up to "something" volts briefly, but will begin dropping as you describe because the IC in control of the backlight senses there's no load and shuts off. This is a very common issue on Vestels.
    Wattevah...
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Your Psu is faulty if you have only 50v but thats only possible if the Pfc is dead. Ips20 will be in standby 120v float on the Led connector no lower then boosted to 160 for 40" and 220 for 50" full array its different for edge lit though so if you have 50v your psu is dead. What is the model lf the Tv first ?
      • speedypro
        • Feb 2013
        • 561
        • United Kingdom
        CELCUS
        Model: dled39167fhd
        • speedypro
          • Feb 2013
          • 561
          • United Kingdom
          TV turns on. Picture shows except backlight. When powers on, backlight comes on and off in a flash.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Dead LED in string....
            Strip panel, test LED's.
            TELEFIX
            • HERETIK10
              MSI GT70 2PE Voltage dropping on the main power rail
              by HERETIK10
              I have a strange problem (for me) on an MSI GT70 2PE laptop.
              When it's under heavy load, power goes steadily to the battery (for 2 or 3 seconds) then return to the charger. If I remove the battery it turns off.
              The higher the load, the lower the voltage on the main rail. We go from 19.5V, PC connected to the charger but turned off (normal consumption of 0.06A)
              On, when it draws 2A the voltage is 19.2V, then eventually collapses to 18.5V (and turns off) around 5A.
              I removed the first 2 mosfets (PQ13 & 14) from the main rail, without noticeable change....
              11-24-2023, 06:06 AM
            • rddube
              Lenovo L490 Ram voltage circuit malfunction
              by rddube
              Hello friends,
              Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
              I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
              Yesterday, 04:41 PM
            • Fernon@Repair
              Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
              by Fernon@Repair
              i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
              VCCIO voltage ok
              VCCSA Voltage OK
              VCCPLL Voltage OK
              Ram Voltage ok
              RamVTT OK
              VPP 2.5 OK
              But No Core Voltage
              and i want to this vrm ic datasheet or pinout (ISL69269)
              anyone have this ic pinout voltages?...
              06-25-2025, 07:19 AM
            • electron_jj
              Panasonic TH-L42D25A checking the PSU output voltage
              by electron_jj
              Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
              I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
              08-29-2021, 08:13 AM
              Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
              by sam_sam_sam
              I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
              The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
              Now...
              06-09-2024, 10:57 AM
