Vizio L32 HDTV10A
  • Fisher77
    • Feb 2016
    • 229
    Vizio L32 HDTV10A
    This tv will not turn on. It has no standby light. I tested the voltage on the power supply. It does not have 5V, 12V or 24V coming out of it. I tested the 2 mosfets, and they are working correctly. No bulging caps. Do not see any burnt components on the board. Would appreciate any help with this.
  • Fisher77
    • Feb 2016
    • 229
    Re: Vizio L32 HDTV10A
    Bump
    • Fisher77
      • Feb 2016
      • 229
      Finally had time to look at this some more today. I found this hot spot on the board. There is a transistor C3209, two resistors, a Zener Diode 1N5383B and a IC - ICE3B1565 all in the burnt looking area. The transistor, and both resistors tested good out of circuit. The Zener was blowed sky high. For the ICE3B1565, I have no idea where to begin on testing it. I was hoping someone on the forum could give me a rundown on the testing procedures for it.
      I took a picture of the nice toasty area of the board.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Those items are indicated in the following repair kit.
        http://www.ebay.ca/itm/VIZIO-0500-05...-/191669959538
        • electomech-fixer
          First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
          by electomech-fixer
          I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
          I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
          09-15-2025, 01:42 AM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
        • howardc64
          Vizio SmartCast TV software bug that looks like hardware
          by howardc64
          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
          11-16-2024, 05:17 PM
