sony tv kdl-50ex645 display problem
  • tonytiger
    • Jan 2010
    • 163
    • canada
    hi guys...
    this is a vary weird situation that i did not see yet,so im hoping that someone will have have this experience before and have a solution.
    so on this tv when power on,everything is ok,video display is nice,menu is nice and clear,this tv is working like it is supposed to be.....
    but as soon as i plug a input source(hdmi,comp,vga....)and start to play it.the picture come with a lot of vertical white lines all over the picture,but sound ok.and even when i bring it on youtube everything is perfect until i press play on a video youtube.....here are a series of pictures of tv working....
    picture 1 is when tv is on(all ok)
    picture 2,2a is when tv is playing on pictures in sony software in menu.(all ok)
    picture 3 is when tv playing music software in menu(all ok)
    picture 5,5a,5b,5c is when tv playing input in the back panel(hdmi,comp,vga,ect)all of them doing the same thing.even on youtube when pressing play on a video movie,ect...(that is when the lines begin)
    and pictures 4,4b, is when i bring it back to menu,info,ect...(all ok again)
    so where can the problem be....t-con,screen or mainboard....and i did forgot to say that i did updated the last software from sony for this tv.
    hope someone can help me out.
    thank you.
  • tonytiger
    • Jan 2010
    • 163
    • canada
    Re: sony tv kdl-50ex645 display problem
    here are 2 more pictures of problem display on tv when input plugin
    • tonytiger
      • Jan 2010
      • 163
      • canada
      did someone had this problem before or have any info that could help me out,it would be very appreciated.thank you....
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Well , i think that this is a mainboard problem. What happens when play something from a USB?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Images of the boards please ?
          • LITEZONER
            GO BOLTS!
            • Mar 2010
            • 223
            start with easiest thing first, Source, check another monitor or source issue, HDMI cable, Check cable on another set also.
            39 Soldering Iron burns And Counting
            • tonytiger
              • Jan 2010
              • 163
              • canada
              thanks for replying,like i did explan,all input does the same(have vertical line all over the picture)but at soon as i go in menu and put photo screen savers,or anything that is in the menus will have a very nice picture....when i go on the internet like youtube....picture is perfect until i press play on any video so there are no more input since it is wireless.....
              that why i do say the problem to be weired.......
              i will have photo of board later tonight post for you....
              i was guessing t-con board,but picture is good on menu,ect...
              so i was wondering since mainboard have somekind of pre-loaded photos,ect...could when a video signal given in anyway, affect screen this bad.....
              • tonytiger
                • Jan 2010
                • 163
                • canada
                when usb,hdmi,comp,ect... plug in,same thing,video have vertical lines on picture
                • tonytiger
                  • Jan 2010
                  • 163
                  • canada
                  here are photo of boards
                  • goodpsusearch
                    Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
                    by goodpsusearch
                    Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
                    First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
                    05-05-2024, 02:04 PM
                  • Carlos#2003%
                    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                    by Carlos#2003%
                    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                    02-15-2024, 07:52 PM
                  • dkneyle
                    Sony KDL-46HX850 Can't upgrade/update firmware
                    by dkneyle
                    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                    09-25-2024, 10:44 PM
                    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 05:27 AM
                    Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                    This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                    09-06-2024, 05:30 AM
