EAY39333001 PSPU-J704A no VS/VA
  • paulstef
    • Dec 2013
    • 724
    does anybody have useful information to troubleshoot this power supply. It boosts the input voltage to 383V and logic voltages are there also, no VS nor VA though. What I have done/measured so far:
    Disconnected the board from logic board and YSUS. Should come on automatically.
    - checked all electrolytics, checked resonant PSU caps, checked all bigger semiconductors (no shorts), white ceramic and other power resistors, all smaller diodes, replaced L6599.
    - L6599 doesn't seem to get a voltage higher than its reference voltage of 1.25V at pin 5 STBY, so it probably stays in a so-called idle state.
    There is one schematic of this PSU on the internet which has nothing to do with this board, looks like it's from a LCD TV...
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: EAY39333001 PSPU-J704A no VS/VA
    http://elektrotanya.com/?q=showresult
    Did you get the schematic from here?
    If not type EAY39333001 in the search field.
    • paulstef
      • Dec 2013
      • 724
      Yes, for some reason this schematic is all over the place. It has a big 24V output and no VS/VA whatsoever, parts do not correspond at all. Definitely an error.
      The TV I have is a plasma TV.
      • paulstef
        • Dec 2013
        • 724
        This training manual shows a power supply very similar to the one I have. Maybe I can go from here.
        • paulstef
          • Dec 2013
          • 724
          After finally measuring the L6599 circuit with an oscilloscope it turns out that the switched bus voltage could be measured unchanged over C801 , the resonant 33n/1600V capacitor.
          Replaced it and circuit works. So even though it showed correctly 33n with my multimeter it had still some kind of high impedance in series.
          • AstutePauciloquent
            Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
            by AstutePauciloquent
            Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
            I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
            11-23-2023, 11:02 PM
          • ohren
            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
            by ohren
            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
            The models launched in 2018 and 2019 respectively....
            09-08-2023, 05:24 PM
          • korben_dallas
            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
            by korben_dallas
            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
            MY QUESTION:
            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
            02-14-2024, 12:23 AM
          • Yanleb
            LG 60PK550 Logic Control Board EBR63450301
            by Yanleb
            Hi all, I just want to share the repair of my 60PK550-UA TV set.
            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
            C57: 3.30V
            C61:...
            07-20-2023, 12:38 AM
          • mferna14
            Logic Board 820-00840-A Missing EDP_BKLT_EN
            by mferna14
            Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
            07-10-2024, 05:18 PM
