Does anyone have the schematic for the main board 312124001523?
					Phillips 52PFL5704D/F7
 Re: Phillips 52PFL5704D/F7
 So, where is this edit button that is suppose to be here? Why can't I just add a file without having to post a reply?
 This is the service manual for the following units with schematic and board layout
 42” 42PFL5704D/F7
 47” 47PFL5704D/F7
 52” 52PFL5704D/F7Attached Files
 Edit button goes away after a pre-determined time.
 Main board schematics are as scarce as hen's teeth!Comment
 If your power supply is clicking on and off, first test your power supply by itself using the PON and Ground. This unit is nice because it will list the current draw on the board for each voltage for load testing. If power supply is good, you main board is most likely bad. There are a few surface mount diodes that need to be checked, if your problem is more then just the diode being bad I would recommend just finding a good used main board, time required to repair is much more then the cost of the board.
 After getting the main board, leave all other boards disconnected and just connect the main board, power supply should click on and stay on, then one by one connect the other boards leaving the tcon till last.Last edited by jotto; 10-21-2016, 11:24 AM.Comment
			by Dani_2024Hi and thanks in advance for any input you might provide!
 Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos
			by ygorsanHi everyone,
 Iām looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
 š§© Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
 07-28-2025, 08:34 AM
			by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
 CN6401
 Pin 01 NC
 Pin 02 NC
 Pin 03 "BL_ON": 0V
 Pin 04 "N/C"
 Pin 05 "STBY 3.3V": 3.5V
 Pin 06 "GND": N/C
 Pin 07 "AC_OFF"...
			by JDCONN 100012588
 Long answer:
			by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
- Loading...
