Logik L32FE13B firmware needed.
  • steviewonder
    • Dec 2013
    • 183
    • england
    Just wondering if anyone may have available the BIN file for the above parcel of junk?..Seems to be unobtanium..Mainboard is TP.MSD309.BP851.
    Set was originally stuck on standby,flashed with the BP85 firmware,not really expecting it to work,And it didn't!....Now stuck between standby and on...
    Thanks in advance for any help!
    Steve
  • steviewonder
    • Dec 2013
    • 183
    • england
    Re: Logik L32FE13B firmware needed.
    Anyone?
    Seems the same board is used in a far-eastern tv, a Starlight 32260st.
    there's firmware available on Amwajsat that may work,but cannot seem to create a account there for some reason...
    • Daniel Larsson
      Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
      by Daniel Larsson
      My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
      I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
      During these seconds the function button is not working...
      08-13-2025, 10:29 AM
    • EduCabral
      [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
      by EduCabral
      I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
      While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
      šŸ”§ Details:
      • Model: YT-M06
      • Interface: Pioneer 1
      • MCU: Fujitsu MB89F202
      • Goal: Find a valid .bin firmware file or memory dump from a working unit
      I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
      07-15-2025, 12:26 AM
    • Daniel Larsson
      Firmware file for Marantz NR1501 needed
      by Daniel Larsson
      I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
      After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
      The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
      The content of these seems to be useless as far...
      05-23-2025, 04:11 AM
    • jorpec
      Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
      by jorpec
      Hi, all
      I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
      10-17-2025, 03:51 AM
    • Robby-Gr
      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
      by Robby-Gr
      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
      Additional issues:...
      09-27-2025, 12:02 AM
