What is needed to repair main board with problems with no picture but has sound?
LG 60PZ550 Main Board repair
Re: LG 60PZ550 Main Board repair
if im correct yours is a plasma so i would upload pictures first of the back of the tv showing all parts because it may not be the main board at fault unless you have already done test patterns to determine the main is at fault ? -
In a darkened room does the panel glow?
Yes, In a dark room the screen glow.
Is the Y-sustain producing a slight humming noise?
Yes, there's a slight humming.
Is there an LED blinking on the control board?
Yes, it's blinking
Did you try the test pattern jumper on the control board?
Yes, and the screen flashes different colors.Comment
Normally if it passes the test pattern test then it does look like a main board fault and possibly a BGA problem. Can you reflow the main board or know anyone who can carry this out.Willing to help but I'm no expert.Comment
Yes I can reflow the main board, from the picture can you you tell me which chip need to be reflow?Comment
It's probably one of the large chips under the black heatsink. What's the part number on IC1500Last edited by dick_barton; 09-25-2016, 03:40 PM.Willing to help but I'm no expert.Comment
I can't find anything under that number so I can't identify the IC, sorry.Willing to help but I'm no expert.Comment
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by ygorsanHi everyone,
Iām looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
š§© Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... -
by JDCONN 100012588
Issue: No Power, Then Rebooting After Main Board Change
Short answer: replace main board and power board
Technical answer: replace main board and Q306 & Q307 on power board.
Long answer:
TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge.... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... - Loading...
