Vizio E420VO replacement part
+ More Options
Posts
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • bstewara
    Vizio P659-G1 Screen Removal / Backlight Replacement
    by bstewara
    Hi All,
    Has anyone had the experience of replacing backights on the “P” series Vizio tv?
    Model number P659-G1
    This type tv has a very small bezel holding the screen in and I’m not sure how the bezel/screen is assembled. ( I’m hoping the screen is not epoxied to the frame)
    Before I attempt this I thought maybe someone on this forum has performed this backlight replacement procedure.
    Thanks in advance...
    09-26-2022, 10:40 AM
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
  • giddyupngo
    Backlight replacement mess, Vizio V505-G9
    by giddyupngo
    Hello, I would appreciate your expertise on this. I have about 5 years experience with copier repair, so I have done a lot of board and component replacement. This is the first LCD TV I tried to repair, and it really humbled me. The issue was that on power on the TV power light would go on and then fade out seconds later, and there was no image at all, screen stayed black.
    I thought this meant there was a power board problem, not realizing that the power light fading out was by design, probably so the light would not distract the TV watcher. This is not my TV, so I wasn't familiar...
    02-09-2023, 09:14 PM
