LG Plasma 60PV450: No picture but sound, even with both Y-SUS and Z-SUS unplugged
  • gpaps
    • Sep 2016
    • 10
    Hello all,
    Newbie here, I have some basic electronic skills but far from advanced.
    Fell on this site by reading about what seems many of the same problems with some Plasma TVs.
    Read through a lof of very very informative posts here. But didn't find any exact solution to my problem:
    My LG Plasma TV 60PV450 suddenly lost picture yesterday, although sound is fine. The screen is completely black, no subtle grey at all as I usually see when the TV first displays when powered on.
    I removed the cover panel, and unplugged the Z-sus from the power board, powered it back on, sound works fine.
    I then waited and plugged back the Z-sus, then disconnected the Y-sus, powered back on, sound works fine.
    I then waited and unplugged the Z-sus, so now both Z-sus and Y-sus are unplugged. Powered back on, sound works fine as well.
    Now I am not sure which of the two boards is faulty? Could it be both?
    If it's only one board I could probably buy a new one and switch it, but at two boards it comes close to a price that's not really worth it for me.
    Parts are harder to find in Canada and shipping/taxes from the US hurts even more.
    Any help from you knowledgable folks would be much appreciated!
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG Plasma 60PV450: No picture but sound, even with both Y-SUS and Z-SUS unplugged
    Post some really clear and sharp photo's and I'm sure help would soon be forthcoming.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      You wont get any image with just the Zsus as the panel needs scan drive from the Ysus to get any light emission from it. Do you have a DMM and know how to use it ? Were going to help you diagnose it so DO NOT just start replacing boards.
      • gpaps
        • Sep 2016
        • 10
        Thank you I am very grateful.
        Yes I have a digital multimeter, I tested the fuses and got readings of 0.1 or 0.2 on them (I think one was 0.18). There seems to be one fuse on the Y-sus board, one on the Z-sus, and 3 on the power supply board and all seem fine.
        Aside from that, I am not sure where else to test without causing a problem or shocking myself
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Right put the meter to ground and set it to 600v dc. Now if you look at the back of the Pdp there will be a chart which has a list of set voltages on it. You need to check that chart and probe the test point areas for the listed voltages on the Psu and sustain boards and compare the voltages to the panel. The voltages will be like this for example:
          Psu:
          Vs-208v
          Va-63v
          Zsus:
          Zbias-96v
          Ysus:
          -Vy -200v
          Only test -Vy/vsc with your meter as others will have very high charge voltages that will be more than the meter can handle.
          • gpaps
            • Sep 2016
            • 10
            Ok this is the part that's a little more advanced for me, but I'll give it a shot.
            The chart says Voltage Setting: 5V / Va: 55 / Vs: 201
            Powered the TV, put the black probe on a ground screw, then the red probe on the VA TP point and then the VS TP point, I got pretty much the same: 55v and 200v.
            Now, how do I test the power to the Y-sus and Z-sus boards? I do not seem to see any TP points on those.
              From my memory on fixing the 60PZ950T I had the Y or Z chains off the other boards.
              So if you unplug Z and it chains off Y then the set powers on then the Z is bad.
              If you unplug Y you have effectively unplugged both Y and Z so it doesn't help the diagnosis.
              It's been a while so I can't remember which way around it works but you probably get the jist.
              • gpaps
                • Sep 2016
                • 10
                If I understand correctly, because I do have sound with both Y and Z unplugged, there is no way to know which of the two has actually gone bad?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  There is test points you just need to look closely at the boards, normally near the pots to adjust that voltage there will be a TP.
                  • gpaps
                    • Sep 2016
                    • 10
                    OK I seem to have found them, wasn't sure that these were test points, hopefully it's the right ones. See attached photos.
                    On the Y-sus:
                    VSC: 150
                    Vy: -177 (normal to read negative voltage?)
                    On the Z-sus:
                    VZB: 11
                    Guess it's the Z-sus that has a problem? If so, any further testing or should I replace that board? Or is it an easy fix?
                    PS: All boards are connected.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      As Tom says the Ysus and Zsus use chained energy recovery meaning if the Zsus has an issue it will cause the Ysus not to work properly. As the Zbais is so low the Zsus definitely has a fault on it thw Zbais fets and the ER are in the same track likely meaning that can cause the Ysus not to work either. I would say replacing the Zsus should sort the issue.
                      • syaoran123
                        • Jun 2014
                        • 178
                        Does the t-con board have a green light? If not, its dead
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Tcon does yes.
                          • syaoran123
                            • Jun 2014
                            • 178
                            Originally posted by ReeceyBurger123
                            Tcon does yes.
                            Are you answering for gpaps?
                            • gpaps
                              • Sep 2016
                              • 10
                              Yes there is a flashing green light on the controller.
                              • syaoran123
                                • Jun 2014
                                • 178
                                controller is working fine then
                                • gpaps
                                  • Sep 2016
                                  • 10
                                  Trying to get the Zsus board out but how do I remove these connectors? Don't want to risk breaking them.
                                  What are they called anyways?
                                  Thank you
                                  • gpaps
                                    • Sep 2016
                                    • 10
                                    Never mind, I just pulled
                                    Here are some photos of the back side, I don't see anything wrong, no cracked solder.
                                    Anything else I can quickly test to see what's wrong with the board that it gets only 11v at the VZB test point?
                                    • gpaps
                                      • Sep 2016
                                      • 10
                                      Should I be testing the buffer boards? Or is this unrelated to this problem?
                                      My screen is totally black. No grey, no half-picture.
                                      • Pop13
                                        • Mar 2014
                                        • 9
                                        • usa
                                        Did you ever resolve the issue with your TV?
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • PlasMatt
                                          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                          by PlasMatt
                                          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                          09-20-2025, 06:50 PM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
